Autoscan, first ever. Putting the newly acquired VCDS to work. Did Wilbur first, now Orville.
Results:
Wednesday,12,July,2017,22:13:48:00816
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: 3VWRP69M13M086753 License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWRP69M13M086753 Mileage: 358180km-222562miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 00066
VCID: 629EA334CD5F82175BD-4B3C
3VWRP69M13M086753 VWZ7Z0B5882584
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 3330167027255B9FE0B-5184
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 2708F220E6FD273F4C3-5160
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 07232
Shop #: WSC 00000
VCID: 313C1C78D839698F927-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70BAD97C13B32087DD9-5160
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 37282260365DB7BFDC3-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0004
7 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio ZSW 0018
Coding: 00031
Shop #: WSC 00066
VCID: 5DE490C8F421BDEF66F-5160
End----------(Elapsed Time: 07:48, VBatt start/end: 13.4V/13.6V)-----------
