diy_fool
I tried this over on the biodiesel section with no replys, perhaps someone over here knows something...
I was wondering if anyone has experimented with the timing using biodiesel for maximum performance. My ride is B100 most of the year dropping to B70 for the winter.
Got to install an 11mm pump this weekend and the performance is amazing according to my butt dyno. It has way more power in 3-4k rpm range. The car can sometimes break the tires loose in first gear if I mash it on dry pavement. That's with new and sticky Goodyear Eagle F1 225's. It could never do that before. My timing is now slightly retarded from nominal.
The IQ is now about 2 with smooth idle and slowdown.
The previous timing setting with the 10 mm pump was running slightly over advanced, just above the line. That's the way it was when I got the car and I never bothered to adjust it.
So I'm wondering if the performance gains are all in the pump and or the timing adjustment.
Is there a preferred timing setting running B100?
