Ontario Karma thread
IAMCIRE
Toronto, ON
BEW Wagon
Anyone kind enough to let me use their driveway/garage to do some basic maintenance/repairs in Toronto? I'll bring pizza beer etc.. and got all tools/jacks etc...
Moved to an apartment and last time I did work on the car management came quickly to tell me to stop. Don't want to get into any trouble again.
Wingnut
Toronto & Whitby
Silver 2003 Jetta Wagon
You are welcome to use my driveway if you don't mind a drive to Whitby. I can also do your hatch & window mod if I haven't already.
Wingnut
Toronto & Whitby
Window mod is so you can roll your windows up & down remotely with the fob. For wagons, the hatch mod is where the hatch is unlocked in sync with the doors, so the fob/door panel button is not required to open it.
Wingnut
Toronto & Whitby
None, I have done hundreds. Just pay it forward by doing something nice to a stranger one day. Buy a coffee for the guy behind you in the drive through, or shovel your neighbors driveway.
krazykipa
GTA
2003 Golf TDI (RIP), 2006 Jetta Wagon TDI
Bunch of free MK4 ALH Golf stuff located by Erin Mills Town Center:
New Bosch 3397013256 ICON Wiper Blade - 21" - fits all MK4 except those with Aero blades
Passenger airbag
Various relays
Battery box
Coolant tank
Washer fluid tank
RR taillight
EGR
MAF
N75
graeme20
Brooklin
2013 GSW
Free Wagon Roof Racks
They're from an an old Subaru Forester, however I used them on both my MK4 and Mk6 wagon. Kinda ugly & one of the mounts is getting to the end of it's life.....but you can have 'em for free.
Diesel_Nerd
Barrie
2003 Golf Tdi
Rusty MK4 Eibach lowering springs
A set of rusty Eibach lowering springs 1.2" drop, absolutely free. Pick up in Barrie.
OhCdn
Canada
2002 Golf MK4
Hey guys in Woodstock area looking for a driveway or garage to do my oil changes in anyone around?
graeme20
Brooklin
2013 GSW
Front oem struts from a 2013 tdi wagon. 130,000 k on them. Just replaced as I had to fix a broken spring and figured I'd stick in new struts while i was in there. They still worked fine. Pickup in brooklin. Free.
Spanky92
Guelph Ontario
2003 ALH Jetta
Anyone in ontario have alh timing tools I can rent or borrow? Water pump is leaking and I'm too poor to afford the metal nerd kit right now...
Boostlee
Canada
03 Jetta wagon
Anyone in or around the Pickering area that wants to get my 03 tdi wagon up to par? looking for someone to work on it $$
reildawg
Markham, Canada
2000 Jetta TDI
Giving away parts for donation/free in the spirirt of the season and needing to free up space. Anything given I'll pass on to Salvation Army. Everything is for MK4 jetta with ALH and manual trans unless otherwise stated. Parts are as follows.
-Tail light set plus a driver side
-Headlight set
-Oil pump x2
-Starter (dunno honestly it's been ages since i pulled them) x2
-Bare block
-Short block (needs tlc, not good to go)
-Injection pump
-Valve cover
-Connecting rod set
-Pistons with pins
-Coolant caps
-fuel tank caps
-truck jack
-owners manual for 2002 jetta
-Horns
-Brake calipers for core or rebuild
-injectors for core or rebuild
-VR6 fuel rail
-VR6 plastic valve cover
-Passenger side mirror assembly in blue
-MK3 steering rack (dunno)
-hand brake assemlby
-Tan glove box
-Windshield washer fluid reservoir with pump
-Oil filter housing tower x2
-Power steering fluid reservoir.
Cheers.
TDIGAZ
Eastern Ontario, Canada
2003 Jetta GLS Grey 5 spd; 2003 Jetta GLS Silver 5 spd (R.I.P.-Collision)
-Headlight set
-Oil pump x2
-Bare block
-Injection pump
-Valve cover
-Connecting rod set
-Pistons with pins
-Coolant caps
-fuel tank caps
-truck jack
-Horns
-VR6 fuel rail
-Tan glove box
Cheers.
reildawg... where are you located?
TDIGAZ
I'm at my parents house in Markham. Sorry the location info is a bit off.
That's OK, my son's in Halifax (stuck in the covid "Atlantic bubble"). But if you were out there I might have had him take you up on your kind offer.
Hopefully somebody can take advantage of this... Happy Holidays.
amit9
Toronto/Scarborough
2003 Silver Jetta TDI GLS 5MT
-Headlight set
-Oil pump x2
-Bare block
-Injection pump
-Valve cover
-Connecting rod set
-Pistons with pins
-Coolant caps
-fuel tank caps
-truck jack
-Horns
-VR6 fuel rail
-Tan glove box
Cheers.
- Calipers - are these front or rear or both?
- Injection Pump is it tested/working?
- Truck jack - is it the factory one?
How much donation would you like for these items? Thanks.
reildawg
Markham, Canada
2000 Jetta TDI
-Full set of calipers with rear brackets
-No
-Yes
Anything is fine
reildawg
Markham, Canada
2000 Jetta TDI
Also came across two stock alloy wheels for a mk4 with old snow tires on them. And a complete front rad support with a radiator and fans installed. Adding them to the list for free as well.
