Oldman
- Joined
- Feb 3, 2001
- Location
- Leander,TX,USA
OK, so for grins, I made a free pop-off valve.
Specifications:
Hobbs switch left at 17.5 cut in, factory TB used with the EGR pipe removed thus dumping the bypass intake gasses out of the factory TB to EGR hole. I used all factory vacuum lines (as this is their original route) and used the factory EGR solenoid valve for control. This appears to be a negative triggered device (FYI). VNT settings at zero, 11mm pump, chip, .205s
Surge in the intake can be controled via the EGR valve venting intake charge to atmosphere. This is a good thing because the VNT-15 maps (as all turbo maps) have surge lines that are MUCH higher at higher flow levels. To put it simply if you going to blow the turbo it will be at high boost and low flow situations, NOT at high boost and high flow situations. So poping some flow is a good thing for wheel longevity. An additional plus(es) are that venting intake charge presents no plumbing or soot problems, is quieter, and it takes almost ZERO time to create such a device.
Results were less than spectacular. Tip in surge can go to 25 PSI and then oscillate at WOT between 15 PSI to 20 PSI. I speculate that the factory valve has a hard time opening against manifold pressure without massive help from the now unplugged EGR. Still this shows that a Pop off is effective and I'd prefer this to any negative VNT mods. I would also think a real pop-off valve should be used. They are CHEAP!!!!!
With popoff in operation, the car seems more powerful and reaches boost much quicker, hmm, don't know why.
On the free EGR wastegate, here is where the testing has reach to my mind a conclusion:
I tried to plumb the wastegate into the VNT control line, we know that this is NOT an ON/OFF binary setup. The factory modulates flow to control the vanes. Well I can get no boost, with even a whisp of vacuum in the line the EGR port opens and there is no turbo spool. I was VERY surprised as I expected some boost even with the port full open. This shows that the EGR hole is MORE than sufficient to bleed boost away. So there is no cheap control for the EGR wastegate cheap = free, Hobbs switch for under $30.00 is the only control method, but I got an angle.
I did also hook the EGR wastegate and the pop off device to Hobbs control. This would be bleeding intake as well as exhaust. To my surprise surge was higher with this setup, as well as the oscillation in boost say between 15 PSI and 22 PSI. Not good. I'm speculating that the factory vacuum supply just is not enough to pull open both valves in a timely manner.
[ March 22, 2002, 19:52: Message edited by: Oldman ]
Specifications:
