O'l silvers tear down
Status
Not open for further replies.
RiceEater
gray 2k2 Jetta GLS
Re: O\'l silvers tear down
Boundless, Go to your closet and get a clothshanger. Compress it in your hands to where it just buckles. Is there a "hinge?" Is it still rigid but bent? Get a paperclip. Twist it, bend it, etc. Does it still support a load? I believe paper clips are a little more exotic steel than most clothshangers but I am pretty ignorant as to how the tdi is constructed.
VelvetFoot
Sand Lake, NY
NB, 2000, Yellow
Gewilli: What's wrong with trying to solve problems? It's fun trying to guess the answer to someone's problem. I think we've collectively saved people from buying at least a couple of injection pumps and turbos. Thing is, in those cases, if you get the diagnosis correct, a part is repaired or replaced, and voila, a healed tdi. This case will really have no solution like that because the patient is dead. Only similar examples from the literature, or expert observations are available as to the cause of death.
Boundless
BANNED
To RiceEater:
A connecting rod (conrod) is a structural column supported on both ends by hinged joints that can not support a significant torque. Therefore, the load is ideally a pure tension or compression load with the forces applied at the hinge supports (the wrist pin and bearing) It transmits a load from one end to the other. The load must be applied along the centerline (longitudinal axis) of the column for maximum strength. When a column is overloaded, it buckles. The maximum load an undeformed column can handle is many times that of a buckled column. Or, a buckled column can handle only a small fraction of the load of the undeformed column. If the load on a column gets close to the maximum a column can bear, the column can catastrophically fail, it will completely collapse. This is why column-loaded members are designed with huge factors of safety, or margin. Not just a few percent of the maximum possible load, but multiples, like 20x, 30x, etc. But connecting rods are not pure columns. Unfortunately, this is not an ideal situation, and non-axial loads are present, which screws things up. The conrods can also be bent from these non-axial loads, which is very different from buckling.
Head gasket issue:
I suppose that head gaskets are not supposed to fail anymore? Why does that make me think of "permanently lubricated bearings" that aren't, semi-boneless ham that is and isn't? How many times have you had to replace those things that are supposed to never need replacement again? Silly me...
To tdimeister:
From your post: Boundless, with all due respect it seems obvious to me with your last post that you're no mechanical engineer but posing as one. I challenge you to describe to me: a) how you figure tensile overload caused the failure of the con-rods that we see; and b) how a tensile force of that magnitude could have been generated, as you said correctly, during the intake stroke alone.
Here is the answer to a)
From my earlier post: From the photos, the connecting rod pulled the wrist pin so forcefully that the wrist pin bosses of the piston were torn right off the piston, a classic tensile failure mode.
In simple English this says, "that the wrist pin bosses of the piston were torn right off the piston, a classic tensile failure mode." Do you see the word 'conrod' here? It clearly states that I was addressing the wrist pin bosses of the piston, no mention of conrod. Therefore, there is no need to explain tensile failure of conrods since I wasn't talking about tensile failure of conrods. You used your Mulligan. Reading comprehension issues won't be dealt with so politely anymore.
Here is the answer to b)
The photo clearly shows that the wrist pin pulled the bosses off the piston. The piston is not seized or binding in the cylinder at all, according to the reports. I maintain that this occurred on the intake stroke when the piston is pulled down the cylinder by the wrist pin. The failure may have occurred towards the end of the exhaust stroke when the deceleration of the piston was high, resulting in high wrist pin forces that cause tensile loads in the wrist pin bosses of the piston. But in that case, the piston is usually slammed into the head and there was no damage to the piston top or the head, so that couldn't have happened. So, the only other way it could have happened was when the wrist pin pulled the piston down some time after the beginning of the intake stroke. The piston mass and some friction between the rings/piston/cylinder caused a force in one direction (up) and the wrist pin exerted the force in the other direction (down). These forces were directed away from each other resulting in a tensile load on the wrist pin piston bosses. This pulled the wrist pin piston bosses apart. These excessive forces are generated by over revs. The higher the RPMs, the higher the acceleration/deceleration forces generated by the mass of the piston. (F=ma) That should be enough. If it isn't, go ask someone else.
So now you know, or should I ask if I am correct?
Okay, I used the easy equation instead of the hard one. I wanted to avoid another piece of information that further shoots down this over press scenario. But, in demonstrating your alleged prowess, you opened another door that you need to close. You calculate that with 35 PSI boost, the pressure at the end of the compression stroke will be 2890 psi. The injection pump is rated at 200 bar or 2900 PSI. The instant combustion starts, the pressure in the cylinder will spike and easily exceed the pressure capability of the pump. How can a 2900 PSI pump pump into a cylinder that is at a pressure greater than the 2900 PSI pump rating capability? If the pressure in the cylinder gets above the pressure capability of the pump, the pump can't pump into the cylinder. Don't even think of trying to say that the pump shoots all the fuel in there real fast and then the fuel burns and raises the pressure. That's not how it works. I'm looking forward to your answer great swami, especially since your calculations show pressures several thousands of PSI greater than the 2890 PSI, all well in excess of the pump pressure capability.
So you did some calculations that produced some pressure figures. They don't substantiate that "That, ladies and gentlemen, is what MANGLED those rods. I'm so sure of it! It's a classical failure mode!" Please explain how those pressures that you calculated mangled the rods. Exactly what is the classical failure mode? You didn't mention that.
It is very difficult to conclusively prove that over press & buckling caused the deformed rods with out actual pressures and conrod geometry. But, certain failure modes can be ruled out by the fact that certain things don't jibe with the hypothesis. I'm sure I have done that. Specifically, the bent rods could not have been deformed (buckled) by over press. It sounds like the over press was an isolated incident. Deforming a steel/iron rod that much so fast would have fractured the conrods. This magnitude of deformity took a long time to achieve, certainly not in the time the BOOM took place as described in an earlier post. The pump could not pump full loads of fuel into a cylinder that was over turbo'd. You guys have shown that in the event of a turbo spike, the cylinder pressures will be well over 2900 PSI, the max. pressure of the TDI pump. This can effectively attenuate or shut down the pump. Do you think that the pump pressure is designed to compensate for turbo spikes, excessive cylinder pressures, or over fueling to protect the engine? This eliminates over press as the primary cause of the deformed rods. Prove that the turbo over press alone (with fat injectors) can cause cylinder pressures that are egregiously (>>30x) in excess of normal operating turbo & cylinder pressures with normal or even 90 hp fuel loads. You gotta prove this while supporting the over press hypothesis. Remember, cylinder pressure much above 2900 PSI effectively attenuates and may even shut down the pump.
See if you can do it credibly and professionally without attacking someone personally to direct attention away from your own weakness and inability. If you really know what you are talking about, you shouldn't be confrontational, threatened or defensive. This isn't a competition, unless you want it to be. Does, "I challenge you to describe to me: a) " look familiar? It's just a place where people can ask for help and those that are nice enough can politely offer it. If you want to behave like that, go to work.
So, tdimeister, tell me about yourself. From the way you present yourself, you must be a post-post-post doc, forgive me please if I underestimated, and your tact and people skills must make you a Sr. VP of a very large & high powered engineering organization, again, please forgive me if I have underestimated. Tell us why we should blindly believe all the unsubstantiated speculative things you have to say simply because you say so.
From your post, you used a freshman thermo equation, readily available from most reference sources, to calculate cylinder pressures. You failed to connect those calculated pressures to the mangled rods. Here is the relevant passage from your post:
from tdimeister: "Do the same with 35 PSI of boost, that's 35 ON TOP of 14.7 PSI, and applying my magic equation again, and I get a figure of 2890 PSI!! Throw fuel into the equation and let it burn, and the peak pressure rises to SEVERAL THOUSAND PSI OVER my original example! That, ladies and gentlemen, is what MANGLED those rods. I'm so sure of it! It's a classical failure mode!"
Right now all you have is unsupported speculation that has a gazillion holes in it. Your pressure calcs did nothing. There is no basis from which to say the pressures you calculated are excessive and caused the conrods to deform. None whatsoever. This isn't a competition, it's about sharing and learning and some of us have a lot more to learn than others. You are quite entertaining although you really aren't saying anything of value. You make it look like you know what you are talking about, but: Where's the beef?
So tell us great swami why you are so sure of it, even though a sieve has less holes than your conjecture, and YOU LIKE TO YELL AND USE A LOT OF EXCLAMATION MARKS TO ATTEMPT TO GET YOUR UNSUBSTANTIATED POINT ACROSS!!!!!!!
To DavinATL:
I like your post. I admit, I was lazy and didn't go into detail. If I did, I'm sure you would have gotten the points. I'll explain the things you didn't agree with in more detail. But, I have plenty experience in this area. I have spent many years of my career conducting failures analyses in the aerospace & automotive industries, mainly concentrating on engines or engine equipment. I also am involved in motorsports and deal with team owners and engine builders that participate in nationally sanctioned racing organizations. I've seen plenty of bent and broken parts along with great details regarding the surrounding circumstances. Also, I did quite a bit of research in combustion dynamics. I'm not one of the armchair guys. Good luck and congrats on the phd. When can I call you Dr.?
First, let's agree that the failure of the #2 piston is probably due in a large part, to the deformation of the rod. The rod problem allowed the piston wrist pin boss to be compromised, leading to its demise. The weakening of the boss reduced the max. RPM that the assembly could tolerate.
Also, I really don't care about the last gasp runaway situation. The damage that could be valuable to understand is the deformation of the rods which obviously happened long before the engine died.
So, let's start with a further explanation of column loading, buckling of columns, design margins, over pressure, and fat (.205) injectors. See the above discussion about columns for RiceEater. For example, let's say we have a column that can support a maximum load of 100#. If the load exceeds 100#, the column will buckle and collapse unless the load is removed or dramatically reduced. The load required to continue the collapse of the buckled column is just a tiny fraction of what was required to initiate buckling. So if it took 100# to initiate buckling, it might take only 30# to continue the failure collapse. Note: I'm talking load and not prescribed axial deflection. (BTW: I was a teaching assistant and ran Strength of Materials labs. I conducted a gazillion column buckling tests on well instrumented samples and equipment.) I maintain that if an over press condition caused the conrods to buckle, there would have been a complete catastrophic failure because once the buckling was initiated, the over press load was not attenuated and therefore far in excess of what would be necessary to destroy a buckled conrod. This didn't happen, so I maintain an over press did not cause this failure - bent conrods or eviscerated piston. Now let's look at how you say the over press occurred. You claim that the fat injectors can pump that much more fuel into the engine and that with the over press spike went boom. Let's look at a stock TDI motor. At maximum output, (90 hp), the fuel flow consumption rate is X #/hr. If you double the fuel flow rate (2X) and assume it could be burned effectively, the engine would have an output of 180 hp. Now, redline is limited to the same max. RPM, so this increased output came from an increase of only torque. (I believe you said ol' Silver never went above 3,500 RPM) (HP = Torque x RPM) This means that cylinder pressures were doubled for the same RPMs. Now, I don't think that the .205 injectors could double the fuel flow rate over the stock injectors and increase the HP that much. The actual increased fuel flow rate is some percentage significantly less than 2X the stock injectors. But let's say the fuel flow was doubled and the air flow was adequate to burn all that fuel. The pressures on the pistons would be doubled, the torque would be doubled and all would be okay as long as we didn't let that extra torque make us zing (over rev) the motor. Even double the output won't bend conrods. These structures (columns = conrods) require huge factors of safety (margins) because of the potential catastrophic results of a failure. Therefore, these columns are designed with maximum loads (Pre-buckle) 20x, 30x, 40x, 50x, or greater than the maximum possible actual load just to make sure the possibility of initiating buckling is minimized. And that is in a static situation. This is a dynamic situation where there is a lateral load and a moment applied to the "hinged supports" that can uncouple the load line (line of action) from the column centerline causing instability that could lead to buckling. Design margins in cases like this are huge. I would have to believe that in order for a TDI engine to live the hundreds of thousands of miles it is expected to under all the insane conditions it will be exposed to over probably 15 years, the buckling margins the conrods are designed to are huge, 40x at least, which means that even if the .205 injectors delivered twice the fuel flow rate of the stock injector and the turbo over boosted and gave it all the air it needed, the pressures still would be far, far below those required to initiate buckling. Look at this way, if the engines that get these .205 injectors all smoke so much as you have said, the engines are saturated and are not producing all the power from the fuel being injected. The engines are not able to fully produce the power from the available fuel (Proven by the smoking) and the additional fuel flow rate is what percentage greater than stock? It can't even be 2X stock. So, in reality, the usable fuel flow isn't even twice stock, (The .205 injectors are only 22% greater flow area than stock.) the torque can't be doubled, the load on the pistons can't even be doubled, the buckling stability design margin on the conrod is probably at least 40x, there is no way over press & fat injector fuel flow rate could have come close to initiating a conrod buckling load.
Boundless: The only force opposing the wrist pin was the mass of the piston.
DavinATL: Aha. Are you sure? Where did that scuff mark come from on the "good" piston photo next to the crack?
Yes I'm sure. Well, add in a little friction. The only force to pull on the bottom of the piston like that is from the wrist pin from the conrod. The only thing that could oppose this (equal & opposite) is the mass of the piston (F=ma). Turbo pressure/intake pressure is obviously negligible. My understanding is that these scuff marks are from the piston contacting the counterweights on the crank as a result of the shortened conrods, which all were shorter, regardless of how "good" the pistons were. Look at where the scuff is on the piston wrist pin boss. The scuffs are on the very bottom of the boss, at least the piston I saw, which is below the wrist pin. This scuffed area would be between the wrist pin and the crank counter weight when the piston is at BDC. The loads from the scuffing and the failure loads that yanked the boss off the piston act on different areas. If the scuffing was severe enough, it could have caused weakening of the boss and allowed the boss to open or rupture on the intake stroke, allowing the wrist pin to be pulled out of the piston. If the crankshaft counter weights were severely hitting the piston skirts, I could accept that as the reason for yanking the wrist pin bosses off the piston like that. It looks like the skirts just chipped away. Also, I believe that the piston that was eviscerated was still up high in the cylinder, away from the counterweights. The wrist pin pulled off the bosses and the piston stayed behind.
Boundless: Hmmmm.... I still don't see it. The fact that the engine survived for quite some time with bent conrods is also further proof that turbo over pressure could not be a causal factor in this failure. If over press had the effect as presented in some of these postings, it would have destroyed all the deformed conrods instantly.
DavinATL: I disagree.
A bent conrod (such as those in the pics) has a maximum load capability that is far, far below (maybe 25%) that of a straight conrod. But the engine still ran without collapsing the rods. The severely weakened rods still worked for many, many miles. (There is a post that indicates the car was driven for 10 hours at 80 MPH @ 3500 RPM up & down hills after the BOOM) Doesn't that indicate to you how huge the margin is to avoid buckling in the first place? And how resistant to buckling the conrods really are? Your argument implies that the deformation we see in the pics occurred all at once - the BOOM you refer to. (BTW - from other postings, it is questionable as to how many times or when turbo spikes occurred.) Well, if you bend a steel/iron rod of that size and as fast as it must have been deformed to end up the way it did, the rods would have fractured because the strain rate would have been grossly exceeded. Have you ever bent a steel/iron rod and if you bent it too fast it broke, but if you went slowly, it didn't break. The same here. Those rods can't be bent like that in the time it took to go BOOM. Those bends took place over a long time, many days, weeks or even months, little by little. Also, when an engine hydrolocks and crushes conrods, the bearings (wrist pin & conrod) are also crushed in very obvious and apparent ways. Now if the hypothesis is that this engine buckled the conrods due to over pressure (similar to hydrolock), the bearings should also be crushed, but they weren't. Also, the wrist pins and wrist pins bosses of the pistons should show signs of severe damage, but they don't. Except for the scuffing & chipped skirts, the pistons are reported to be in excellent shape. In piston & rod assemblies, the piston is the weaker. In this alleged over press, the conrod is the only component that is damaged and all others of the conrod/piston assembly are unscathed. That further casts doubt on an over press. So if the over press occurred, the pressure was transferred through the piston - bushings/bearing - wrist pin - conrod - bearing -crank, and the conrod is the only component to experience directly attributable over press damage. In hydrolock situations, the piston is often the fuse, it fails first, then bearings. I find it very unusual that an aluminum piston was able to survive an alleged over press unscathed while transmitting a force that beat up a steel conrod.
DavinATL: Steve by his own admission (and that of others) was not in the habit of running this engine at high RPMs, and on that I believe him. I don't think that this engine saw RPMs over 3500 until that overrun.
You mean to tell me that this car that has a factory redline of 4500 RPM, and is heavily modified with just about every after market hop up item never went within 1000 RPM of the factory redline? Oh what was I thinking.... silly me!!!! There is also no evidence of lugging.
Boundless: More boost in a diesel could give nothing more than more excess air to more completely burn the injected fuel.
DavinATL: As I said above... there was a LOT of injected fuel from those fat hole injectors that wouldn't have burned at stock air masses. The spike allowed it all to burn.
How much more fuel than stock? 2x?.... Even if it all went off, it couldn't come close to the stability design margin load of the conrod.
Boundless: All this failure mode needs is too much power setting & RPMs way too often. These engines weren't meant for that kind of duty cycle. It's that simple.
DavinATL: But that's the problem. Steve did NOT abuse this engine (well, didn't abuse it by overreving it ). He was light on the foot and kept the RPMs low.
Let's see, ol' Silver had every performance mod known for no reason, and the engine would never be allowed get within 1000 RPM of the factory redline.
Of course, silly me for even thinking otherwise.
Tell me the truth, the whole truth, and nothing but the truth.
Davin, I need something more to believe the over press happened. There are too many holes in that hypothesis, that are supported by the engine condition that ultimately eliminates the over press as the cause of initiating the rod deformation. I'm looking forward to reading what you are thinking. Unfortunately, all we can do is punch holes in the various theories.
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
Couple corrections:
The injection pump will deliver 900 bar. The 220 bar on the injectors is only the CRACKING pressure. That's when they START to open. During the main injection stroke, after the nozzle is fully open, the pressure is MUCH higher.
The eventual failure of the piston was indeed a tension failure, the wrist pin got ripped out the bottom of the piston, but that's likely because the rod had already shortened to less than its original length, and the piston was coming into contact with the crankshaft counterweights. (The PISTON failed - not the rod. The rod is all twisted up, but it's still in one piece.) The piston can't go "down" any more because it's hitting the counterweights. The rod is being pulled inexorably downward by the rotating crankshaft. Something's going to give, and the piston skirt is the weakest part, so that's what broke.
Boundless
BANNED
Brian,
Thanks for the pump pressure info. I was always doubtful of the 3000 PSI (200 bar) number, but never made an effort to look into it. Can you refer me to a credible source of the pump specs?
I can't find anything that goes into good detail about the pump and overall system. I'd like to find some literature, manual or Bosch book that discusses the system control algorithm. If you know of this, I'd appreciate it.
Also, even 900 bar pump pressure doesn't change the content of my previous post, maybe the pump through, but the max. cylinder pressure is still capped well below what I believe has to be a generous buckling margin.
[ November 09, 2001: Message edited by: Boundless ]</p>
RiceEater
gray 2k2 Jetta GLS
Boundless should then support his argument with at what rpm would the forces then bend the connecting rod and use reasonable numbers like the piston weighs 1 pound (or if actual numbers are available?) and say 50kips for the yield strength of the steel (do we know what kind of steel?). For instance at what loading would a connecting rod collapse under compression as compared to what loading a connecting rod would bend under tension? At what piston, rod, crank position would these forces be present?
GeWilli
lost to new england
none in the fleet (99.5 Golf RIP, 96 B4V sold)
Velvetfoot,
I guess my frustration is that this is very much like doing an autopsy on a body through the computer, with a morgue technician that has seen lots of bodies but hasn't passed biology or medicine classes. With the police report in 30 or 40 mixed up pages.
We need to
#1 - makes sense of the "incident report" get an agreeed on circumstance and event sequence that lead to the "death" of the paitent.
#2 - report factually every detail that is present to analyze
#3 - THEN start to analyze the cause of death.
Only with #1 and #2 fully understood by ALL parties can #3 even begin to be rationally discussed but the group. So far I see very little of #1 and #2.
Why? Well the continued occurance of threads being locked down, contributes a small part, the incomplete and spread out nature of it all, the huge quantity of non-forum email traffic on this matter between a smaller group of people, and the general vaugity of the subject. . . .
How about this:
Give this situation a year. But don't stop thinking about it.
I propose a 'scientific/professional' type meeting at the 2002 Fest. Specifically to deal with theories of T.S.'s exploded engine.
I propose that Drivbiwire have it prepared for display and inspection at that point and for those who wish to examine it prior to writing their positional paper.
Anyone that thinks they can explain the cause of the failure should present this as a paper, submitted first 2 months before the meeting. Once the papers are all submitted, the abstracts will be put together intoa collection and distributed to all the "participants" and debate and counterpoint can occur during a specific time point.
Impartial moderators will be running the meeting.
What does everyone think of that idea? You may continue to ask questions, probe for detials but keep your "theories" to yourself until the meeting?
I doubt we will learn anything from this that would help anyone else, the gross lesson is to not do what steve has done. The lesson on what actually happened will be interesting but isn't doing anyone much good in this form IMHO. . .
GeWilli
lost to new england
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by Boundless:
Head gasket issue:
<hr></blockquote>
Well you didn't go back and read the headgasket discussion. It isn't a gasket - it is a shim. For spacing, not designed to be replaced at a regular interval. It is a Copper shim. Sure copper is soft. We are talking about a veyr very thin metal shim clamped between the head and the block. I ain't no ME but I go so far to say I have a pretty damn good idea about pressures and stuff like this and about the engine. You've got a large number of bolts holding this head down on the block, and between the block and the head you have a thin metal plate. Tell me how is this metal plate going to blow out? I can't concieve of a mechanism in which the copper might actually give way without causing inelastic stretching of the headbolts, maybe plastic stretching or elastic stretching would occur but I doubt that. . .
Let's see, ol' Silver had every performance mod known for no reason, and the engine would never be allowed get within 1000 RPM of the factory redline.<hr></blockquote>
Well, shame to say, you along with 90% of the other people condeming a poor man without knowing him. Very sad. Yeah he pushed it, but so rarely that it didn't matter and when he says he never pushed it past 3500 he didn't - boost pressures and power spikes might, when you understand the dynamics of this engine mean basically that you don't need to get past 3500 for power - but this guy was doing all this not so he could use the power like say some weasely butt hotroddin a 57 chevy would but so he could have the power - so he could see what is needed to get a wee bit more efficiency - ah never mind. Too bad you don't understand Steve.
[ November 09, 2001: Message edited by: GeWilli ]</p>
michTDI
Charlotte, MI, USA
2003 Jetta and 2015 GSW MT
Yeah-I pretty much agree with Geoff-there have been so many different stories/versions of stories/misinformation (or at least not sure), what was modded when, etc. etc.; were parts really changed out before Steve bought the car??? I'm not even sure if that was ever conclusively determined. Allegations that VW purposely made codes appear (that weren't there before) etc. etc. etc.
It has taken on a life of its own-and the "victim" himself (Turbo Steve) hasn't said much at all-at least not on the forum.......
It was mildly amusing for awhile-but its gettin old..........
Gotta admit though "with a morgue technician that has seen lots of bodies but hasn't passed biology or medicine classes" that was pretty funny...........havin a bad day Geoff???? Knickers in a twist are they????
GeWilli
lost to new england
nah just trying to be somewhat humerous Clay
hopefully it didn't get taken as an insult - I was just trying to put a funny spin on what I have been observing!
GoFaster
Moderator at Large
2006 Jetta TDI
DaveinATL: Rods are in bending every time the engine turns, due to the acceleration of the rod in the sideways direction as the crank rotates. At the top pivot point, it sees only axial loads, but at the crankpin, it's seeing inertial loads. It's as if the rod were being supported by gravity sideways, only in this case the "gravity" is the inertia of the rod.
PS - DBW maybe? - another thing that would be nice to know is the actual weight of the piston and wristpin combined ... then we can compare the combustion loads to the inertial loads under different load and speed conditions.
I'll revise my buckling post above when we get better info on the length and cross-sectional area of the rods. I think my estimate is low (I'm used to Yamaha FZR400 engines!) and I think your estimate is high. We'll see.
TDIMeister
Canada
I'm short of time but I'll try to condense things.
Boundless, I apologise if the tone of my post sounded condescending; I don't see it save for the posing as an ME bit, but posting the numbers as you did that immediately set me off... it's not a question of easy or hard equations; it's about the right ones or the wrong. Sorry to put it so bluntly. There never was any intention of a personal attack and I'm stunned that you would consider what I said as such... think of my post as a peer review
I'm not a respecter of what one does for a living or what degrees they've earned, and neither do I expect others to see me in the same light. I'm not some cocky Sr. VP of a large engineering corporation; in fact I work in the trenches, but my line of work in an engine development company requires that I have particular expertise in this sort of thing. Nonetheless, I will concede. We are all on the same side. Opposing views we may have, but we have the same goal of trying to come to understand the precise failure mode of the engine and not to put each other down. Agreed?
Anyway, I tried to obtain a TDI rod today with no luck. Thinking about it further, I also concede buckling is a very poor choice of words to describe what happened. As was so eloquently and accurately mentioned before, buckling would imply a compressive axial loading at the exact coincidence along the axis of the con rod. The only time this is happening is at exactly TDC and BDC. At every other point there are significant bending force vectors, so DavinATL, I must say that although your estimate of the threshold compressive load under pure bucking is correct and way beyond what a TDI will ever see, that figure is SIGNIFICANTLY reduced when bending is brought into the picture, such that I STILL maintain that the failure mode was excessive gas pressure and not over-revving. I hope I'm wrong and I eagerly await hearing chilled-out arguments to the contrary. More later.
Late addition to cover-up a "hole" here: 2890 PSI at the end of the compression stroke didn't mangle those rods. We're talking about a CYCLE here. 2890 PSI AND throwing fuel into it and letting peak cylinder pressures WAY beyond design limits mangled those rods. Ladies and gentlemen, your cross-examination.
[ November 09, 2001: Message edited by: tdimeister ]</p>
nuke
Si-Valley, CA USA
Do the .205 injectors have the same 2-stage and slow injection characteristics as the standard 66kw injectors?
That VW info page seems to make a big deal out of that, both for noise and mechanical load:
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr> To minimise the combustion noise level in the diesel engine and keep mechanical
load low, it is necessary for the pressure to rise gently in the combustion chamber. … Also, the fuel should be injected gradually, not all at once. <hr></blockquote>
I also kind of wonder what happens if the hole in the injector is bigger, but the pump is delivering the same volume and pressure. Will the spray pattern be significantly affected or combustion altered?
RiceEater
gray 2k2 Jetta GLS
I believe that there are people on this forum that are working 25/8 to save me from anthrax, smallpox, ebola, etc. and they come to Fred’s forum because they enjoy their tdi’s. There are people on this forum that are trying to save a late harvest semillion from bortrytis. There are people on this forum who prepares the finest chateaubriand on this planet. No, not all these people can resolve a wronskian and too many postings are I'm Dr. so and so and I'm smarter than you and you and you. But yes now this thread is beginning to look like FUN! Unfortunately I glow in the dark so when you say buckling its kinda different for me.
Davin
L.A.
2001 Golf GLS 5spd blk/blk
tdimeister:
you're right. the equation that I posted above is for pure buckling with no other loads. putting bending into the equation significantly effects things.
although like I said before, I'm not qualified at this point to figure out exactly why those rods bent, I now think that the bending didn't happen all at once. the point that boundless made regarding this is strain rate. I don't think that that much bending could have occured all at once during a single power stroke because they probably would have experienced brittle failure rather than ductile.
also, RiceEater... I don't know if your "Dr. so and so" comment was directed at me... it probably was. my mentioning my degrees (and simultaneously pointing out the degrees held by other people on the forum) was an effort to counter a previous statement implying that most people on the forum don't know thing 1 about materials and engineering and are just speculating with no basis in education or experience. I admit that I'm not an expert on engine design and there are people here that are much better versed in it than I am. But I believe that I have a little more insight than the average joe off the street when it comes to these things. maybe not much, but at least a little...
besides, a degree gives you little more than a basis of knowledge to build on. nothing more. in the real world, experience tells how good you are!
now, everyone back to the speculation and argument. I'm learning a lot here!
-davin
Sun Baked GL
Furnace Valley, AZ
If you're running a very high rate of boost and highly advanced injection timing, won't you be risking the possibility of bent rods due to the combustion beginning too early?
The rate of pressure rise in these diesel engines is quite high (100s of thousands of pounds per sq. in. per second) from the combustion.
So don't you have a pressure wave front from the combustion moving towards a piston coming in the opposite direction.
Isn't there the possibility the momentary impulse created when these two forces meet is just enough to exceed the limits of the rods?
[ November 09, 2001: Message edited by: Sun Baked GL ]</p>
GeWilli
lost to new england
no scanner at home so I had to sketch on the 'puter in Photoshop
no CAD stuff anyway, just a sketch.
I kinda hit me that when the crankshaft is out to the side (blue dots) that well the load isn't so up and down, and yeah max compression would be at straight up and down as would combustion. BUT if position 6 there still at an angle just before verticle when the pressure to strength favors pressure the most that is the point where it would seem that the piston would be the weakest - then at that point you might only bend it a millimeter or two to the side - but at 7 and 8 you no longer have a straight line and well as it begins to bend. . . contact is made with the counterweights - ECU adds more fuel to compensate for the reduction in RPMs due to resistance, then it breaks free and POOF . . .
you know after writing this it sounds a little like what a few others have mentioned. Hey you M.E. types - whaddayathink?
RiceEater
gray 2k2 Jetta GLS
At more than 90 degrees before top dead center the connecting rod would be rotating the same direction as engine rotation. At less than 90 degrees before top dead center the rod would rotate the opposite direction of engine rotation. It appears that for any given rpm, 90 degrees before top dead center on the compression stroke is where the greatest bending moment would be applied to the connecting rod. But would this be more stressful than 0 to 5 degrees after top dead center on the power stroke? Accordingly for the piston at less than 0 degrees before top dead center the piston is moving "upwards" and at more than 0 degrees after top dead center the piston is moving "downwards" would be where the piston experiences the greatest acceleration, i.e. the wrist pin pulled out the bottom of the piston at the end of the exhaust stroke, beginning of the intake stroke.
RiceEater
gray 2k2 Jetta GLS
Its getting late and my head hurts but the connecting rod has more bending moment at the end of the compression stroke than at 90 degrees before top dead center when compression is considered in addition to rotation.
Drivbiwire
Zehntes Jahr der Veteran
Boise, Idaho
I'll tell you what, I am willing to send to any of our resident engineers a few of the parts for a diagnosis. We have four rods, a whole bunch of bearings, bearing caps, 3 1/2 pistons
and a couple pounds of shattered metal in the oil pan. Gewillis is going to get the oil filters since this is up his alley.
Lets see if we can come up with a list of who gets waht so we can put together a paper. Once we get a list together I can enclose the CD so that the person examining that part can look at the part before it was removed from the engine. THis will hel them to identify the final resting place and maybe understand how it met it's end.
I would prefer to limit the parts to only those that have access to the equipment to diagnose these types of failures.
My simplistic preliminary diagnosis is actual combustion pressures bent the rods. This means over boost alone did not do this, .205 injectors alone did not do this, weakened piston pins did not do this. What I think happened was the combination of overboost, .205 injectors and sustained power eg climbing mountains coming together to exceed the combustion pressure limits of the motor to bend the rods. If I were to describe the connecting rods I would define this as a "Soft" failure. This is something that occured very slowely but under a relatively long duration. The final failure as far as I can tell was when "one" of the damaged pistons could not hold the wrist pin any longer and broke free from the piston skirt resulting in the failure we have seen.
Gewilli I think having a layout of the motor is an excellent idea and would be great to let everyone look at the insides of a TDI like most have never seen! Huge thumbs up on the idea and you can count on all the parts being there!
Later,
DB
DB
GeWilli
lost to new england
Any requests for SEM imaging or EDS analysis on any of the parts let Pete know and he can get them to me. . .
I will image what ever anyone wants to and provide them to everyone - if I can get it in my SEM.
I hate to say it but Pete has made some sense here
GoFaster
Moderator at Large
2006 Jetta TDI
Buckling load:
(pi^2 * E * I) / (K * L ^2)
hope you can make sense of that.
pi = 3.14159
E = 29,000,000 PSI (within a few percent for all types of steel)
I = moment of inertia in the weakest direction ... probably along the crankshaft axis, in this case - although end constraints are different in the lengthwise and transverse directions
K = a factor which depends on how the ends are constrained, it's in the 1 to 4 range, I'll have to look this up in a textbook tonight.
L = length of the column
We don't know the cross section of the rods but in the absence of any information let's assume 10mm x 20mm rectangular (0.4" x 0.8"). In reality it's an I-beam section. I'm told that the length of the rods is 144mm but you can only use that length when looking in the pin-jointed direction (along the crankshaft). If you look at it the other way, L is shorter and the end-constraint condition is different, because the crankpin and wristpin areas are built up much more and constrain the ends. So only an order-of-magnitude calculation is possible with what we have on hand right now.
Remember that 20,800 lbs of calculated down-force on the pistons? That's in the same order of magnitude as my ballpark buckling load calculation. I'll revise this if someone coughs up some better information that I can use for the cross-section and for the length between the built-up area at the crankpin and the wristpin.
Drivbiwire
Boise, Idaho
Brian I will get some dimensions off the rods here in a little bit, I will post the numbers under this message as an edit, be back in a few...
DB
TDIMeister
Canada
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by Drivbiwire:
DB
<hr></blockquote>
Well, if you REALLY want a professional job, I know of at least one company intimately familiar with TDIs that would gladly do a full failure analysis... for a price...
OTOH, My materials eng. prof. is an expert at structural failure analysis...
GeWilli
lost to new england
I think I should re-emphasize something - I don't want to squelch the discussion as to theories - BUT lets limit it to the evidence - disregard Steve's driving habits - propensity to modify and all that - stick to the evidence and try to explain what happened.
Brian - Damn you got some good info
I always new there was a couple brain cells firing under all that grease and oil you are covered with when I see you
Davin
L.A.
GF: I was about to post the same equation!!! That's the critical load for the first mode shape.
boundless: now this is the kind of discussion that I like
It's apparent now that you have more experience than I do in diagnosing failure modes. Although I have a graduate degree, it's in controls and my knowledge of materials hasn't advanced as quickly.
I did some back of the envelope calculations with the buckling equation that GoFaster posted. I think that these calculations disprove my buckling theory, and add evidence to your and DBW's gradual deformation theory.
Let's assume that the rods are steel. So the modulus is ~200 GPa. Also, we'll model the cross section as rectangular. This is conservative and will result in a larger critical load than actual. We'll also assume a pinned-pinned coniguration, so that k=1.
The bore of an A4 engine is 79.51mm according to the Bentley. From DBW's photo, I estimated that the cross sectional dimensions of the middle of the rod are 0.2*bore by 0.4*bore. The column length is about 0.75*bore.
The moment of area in the direction that it bent is bh^3/12, where b is the smaller dimension and h is the larger.
Put all of these together and you get a critical load of:
5.3 MILLION POUNDS
That would require a peak cylinder pressure of
690000 PSI
Now, the peak designed cylinder pressure for the TDI engine is 130 bar, or ~2000 psi. There is NO WAY that engine saw 690000 psi. Even if I'm an order of magnitude off... let's say 50000 psi... the buckling load required is 25x design peak cylinder pressures.
And this is why I think boundles knows what he's talking about. He quoted design margins in the 20-40x range, and that jibes with the numbers.
So... the bending likely happened over a long period of time. Although, with the fat injectors, it could have happened with a heavy foot even at low RPMs. Who knows? That's a hard problem to tackle... how did the bending occur. Clearly it wasn't a manufacturing defect, as all rods were bent in a similar manner. Hmmm.
As for the final failure condition when the wrist pin broke through the piston:
Pete, when you disassembled the motor, was the piston high up in the bore or low near the crankshaft? I think that this can tell us if the failure was due to inertial loads or due to contact with the crank weights.
I'm not going to get into calculations of forces required to separate the pin from the piston. I think it's impossible without knowing the geometry of the piston boss and the nature of the cracks that were apparently present in the piston before failure.
boundless: kudos. You proved me wrong! Or, actually, gave me the incentive to prove myself wrong
-davin
[ November 09, 2001: Message edited by: DavinATL ]</p>
VelvetFoot
Sand Lake, NY
NB, 2000, Yellow
Hey GeWilli, this is fun! And to that end....
Is a scenario possible where the injection timing have gotten out of whack enough so that the combustion was working against the rotation of the crank under certain conditions (ie accelerating) when timing would be more advanced?
Status
