r11
outta have _something to rant about
and that would be the 4 way mirror regulator switch:
- awkward location. Never seen a car quite as bad in that respect On our cars, it is mounted on a left side vertical surface !
- they managed to add mirror heater switch to the same control (!?). Logically it kind of belongs there, but what a pita to operate . The rotating switch has most vague feel to it and it feels like it is going to break every time you use it.
Why or why wouldn't they just activate the mirror heater when you engage rear defrost - like every other car out there ?
Here in Northeast, we get quite a few mornings when the mirrors are all mist covered in the mornings and heated mirrors are a must. Every time that happens, rear window is all fogged up as well, so single control makes most sense.
Say you want to adjust a mirror angle while driving. Never an issue with any other car, but here, forget about it ! Can not use left hand, unless you're a contortionist. Have to reach with right hand .... bad bad bad
And ... get this ... when you turn the heater to "on" position, the heat is on till you turn it off. At least they make it most intense for 2 mins and then back off, but you still have to remember to turn it off ... no indicator to remind you about the fact that is on either.
VW, if u r listening: move the darn control to somewhere around window control cluster. Ditch the heater control and have the mirrors heat up when "rear defrost" is turned . And just like the latter, make it turn off automatically after a set interval.
