redding
A few weeks ago while driving home, my oil pressure light came on as I was pulling into my driveway, and I immediately turned off the engine. I routinely check my oil level so knew it was good, but checked it anyway and confirmed it was topped off. Some google searching led me to replacing the oil pressure sensor in case it was faulty. Afterwards it drove fine, but about a few days later the oil pressure warning light came on again.
At that point, I did what I should've originally done which was to use the oil pressure switch testing procedure in the manual, and I verified the switch and the pressure is good. However, since the warning light rarely comes on, and does so at random, I couldn't test the pressure while the warning light was on.
I haven't driven it since, for fear it'll lose pressure while I'm driving somewhere that I can't turn off the engine fast enough.
I read somewhere that fragments of "junk" can get into the oil pan, sometimes covering the oil pickup. Someone said it's likely a fragment from a cracked timing belt cover, since they said those are known to crack. I even found one video on the interwebs of a guy with the same issue on his TDI - he dropped the oil pan and found a few fragments an inch or two in size, but he wasn't sure what they were.
I have tools and some know-how (do all my own maintenance less timing belt), so I am willing to drop the oil pan to remove any fragments if that's the best way forward. But I'm thinking if there is a cracked timing cover (or something else), it should be dealt with or could eventually drop more fragments into the pan.
I'm inclined to drop the pan to check for and remove any fragments, but have a few questions (below) and am open to any suggestions:
1. Is this likely caused by fragments in the oil pan blocking the oil pickup?
2. What are the most likely souces of those fragments?
3. Assuming it might be the lower timing belt cover, how hard and time consuming is it to inspect to see if it is cracked?
