powerram250
I need to replace the plastic plate behind the crankshaft pulley. Long story but the timing belt wore a groove through it from a tree pushing on it. It looks like I need to remove the oil pan foam, then the oil pan, then the aluminum oil pan extension. I need to pull crank timing pulley then the seal plate should come out after removing a few bolts? If I could figure out how to upload pics I'd put them on.
