300D
The three bolt cover plate at the bottom of the oil pan is leaking a bit. Where the oil sensor that is not there goes. Pulled it off to clean up, reseal and reinstall. Turns out there is an O-ring there. Anyone know the part number for the o-ring? Or a compatible one? Also, when reinstalling, I was putting less than 8-10lbs torque to tighten and one just kept turning. Really not any pressure at all. It’s a captive threaded hole. Anyone out there repaired this with a insert? Not sure the thickness available. Or is it just buy a new oil pan? I actually have a spare pan, but would rather not as the pan is nicely sealed in place from the engine being swapped in about 7 months ago.
Thanks.
Thanks.
