dogdots
The oil pump creates the flow, the restricted oil passages and tight tolerances between the moving parts and the bearings creates the increased resistance to flow, thereby creating higher oil pressure in the system.Man, I should get a stack of bearings and drill a hole through them all.
Get rid of the parasitic power loss caused by the oil pump.
Of course the oil pressure is made by the pump. The only thing remotely close to what you're saying is with the rod bearings, where the oil pressure is amplified by centrifugal force from the crank spinning.
Look at it this way...your heart pumps your blood through the restrictions in your arteries, creating blood pressure. If you have a massive arterial blowout, your blood pressure drops to near immeasurable levels.
The centrifugal force of the crank spinning has no effect on oil pressure.
