My TDI is on the last legs of its powertrain warranty, so I decided to check for any oil leaks. The last one around the crank pulley seems clean after 6K, but I found an interesting one near the back of the engine. Looking back at pics from around the other post, looks like this one was already around back then. The subframe right underneath white CV joint splash shield is wet and so is the underbody splash shield right underneath. This area should be right underneath the turbo, so is the leak coming from there? I cant tell as it's a tight squeeze and everything looks clean from the top (thanks, gravity).
I'd like to piece together something more concrete for the dealer to work off of, other than "oil is leaking", so they dont just clean it up, brush me off, and send me on my way.
Looking from ground up towards the EGR/turbo/DPF area. Oil residue around the white shield (front drive axle in the foreground, tranny on the left)
Top side of the drip shield, pointing towards front of car. Oil pooling near the bottom of the ring/bushing
