There is a continous leak in between the timing belt guard and the head. I took off the valve cover to inspect. The valve cover was intact, and I proceeded to take a look at the cam shaft seal. It seemed parallel to the groove. Is it only that seal that can be causing this leak? I put some gasket maker in the valve cover corners to no avail (Orange in pic 3) TDIClub says i've used up too much photo space... heh.
Wiped off:
1.
2.
Put back together and ran again:
3.
4.
Wiped off:
1.
2.
3.
4.
