its not just crank case vapor, its also oil from the journal bearing of the turbo.
but yea, it would be odd to find one that does not have oil in it. they all do. if you drain the intercooler, you should have no more than like half a cup to as little as a few tablespoons.
the fact that its dripping from it means its leaking, fix the leak. its a boost leak for sure, if oil can drip out, so will air.
