cowboyjack
I have done a ton of searching and read every thread on this I could, but I wanna pick the brains of you all that are running bypass and remote oil filters.
I am thinking of using an Amsoil BMK 13 type of remote filter and bypass filter dual set up on an A3.
www.amsoil.com/storefront/bf.aspx
I looked at the oilguard set up, but the Amsoil seems to filter better?
I know some folks like Drivbiwire have used the oilguard for many miles, what are your long term thoughts on both systems?
My concerns are:
1. Driving for hours in the 100+ degree heat of Southern Arizona.
2. Extending the life of my A3 past 250,000 miles.
3. Filtering the soot as much as possible, reducing engine wear.
I have a 98 Jetta TDI with the AHU engine that I picked up with 48,000 miles on it in 2006, am now up to 70,000. I drive it like I stole it, over-maintain it with regular changes of Rotella T 5/40wt synthetic oil, filters, etc.
I have new Sprint 520 nozzles and plan to add a mufflerectomy and a mild Aligator tune, shooting for about 110/120 hp with about 200 ft/lbs of torque. Will add EGT, boost, oil temp and pressure guages.
Also thinking about a Cat 2 fuel filter and EGR delete and/or CCV filter.
Suggestions?
Thanks in advance for your time and your advice.
My concerns are:
Suggestions?
