weedeater
er...you don't attach the intake to the sump. You attach the outlet to the sump, or a suitable tapped hole in the valve cover. You attach the intake to a suitable pressurized source, like the oil pressure transducer port using a tap (T-connector).
Lots of folks around here have done it with either the Amsoil unit or the OilGard. Do a search and you should find threads and pics.
