sodapop6620
After stopping in Fredericksburg, Va for fuel I passed a slower car. I noticed a small cloud of black smoke. A couple of miles later the car was loosing power. After a little while longer I started to notice a white cloud of smoke. This is most evident when I let off of the go pedal and got back on it. I was thinking that I got bad fuel. Well, I made it into Pa. and stopped at the visitors center. After leaving the visitors center I noticed the check engine light was on then within a mile the oil light came on. I stopped at a safe location and looked at the engine and found oil all over the back. I had the car towed home I never smelled burnt oil during the trip.
After getting home I checked the oil level and there was none. I looked around to see if I could figure out where the leak is coming from but I cannot locate the source. I did find that there is oil in the tube that goes into the EGR then onto the intake. Now the egr is covered with oil.
Any ideas as to where to check for the source of the leak would be appreciated.
