domenic123
TDIClub Forums
VW Passat Family (NMS and B7) TDIs (2012+)
2013 Passat
Hi everyone I'm looking for some help regarding oil consumption. I'm burning a litter of oil every 300 miles [highway miles] ,crazy. I put brand new turbo from the dealer i put brand new valve cover , oil filter housing .No leaks on the outside of the engine.The intercooler hose is full of oil everytime i chek it so im pretty sure the oil is coming out of turbo seals .Im runin 15w 40 castrol oil but i tried everything from motul to liqui molly same issue.All the installation has be done correctly drain oil line and everything .I run different test and came in the conclusion that i dont have a crank case ventilation issue no oil getting sucked from the valve cover .no blow by to restrict the drainage .i read somewhere here about the o2 sensor giving the wrong singal to the throttle beeing wide open leading the turbo veins to on open position i put new sensor from dealer . No oil on the exhaust side. Again i only drive mostly highway at 75 85 miles i know it has some effect on it but 1 liter per 300 miles is not acceptable.Any opinion is much appreciated
2013 Passat
