93 1.9d
hey guys one of my mechanic friends who has owned a few of these mk3 diesels had a look at my engine, and what he said was that i probably need to pistons rings because of excessive blow by. Oil leaks at the dipstick, just before the pvc puck, and the valve cover, car does use/burn oil im unsure of the amount because up until now i just topped up when needed but ill try and keep track of it now. I took this video to show just how much pressure is coming out. Engine is difficult to start when cold or hot, now that the weather is warming up i was hoping it was just a glowplug problem but would this severe lack of compression cause the hard starts and long cranking time. Vehicle also idles very rough around 900rpm and when i had the oil changed at a local vw specialist shop ( autobahn motors, they all have a funny german accent so its worth it ) they noted my engine as "running very rough" on the notes. Any idea are appreciated and if its rings, what kind? where to buy?
THANK YOU
http://youtu.be/yQKKz21Yx4c
THANK YOU
