Official: SFBA Dyno Day 4/10
dlai
The Insane Asylum Known As CA
2005 Passat, Stonehenge Gray, 2002 Black Golf 5M
Hi Gary: Glad to hear you'll be able to make it. Should be interesting to see what kind of power all the different cars and mods will be putting out. See you then.
dlai
TDI369: So, I hear you got some new injectors installed!!! /images/graemlins/eek.gif You might want to consider putting your car on the dyno to see what kind of power it puts out...
Updated list:
The current members signed up for dyno runs are:
1. Chugbug (Jolene)
2. Bogstomper (Rudy)
3. dparnell (Doyle)
4. GassinGerhard (Gary)
5. Peter Cheuk (Peter)
6. First D (Eric)
7. mackwood (Jason)
8. dlai (Dan)
9. Hesh (Chris)
10. scruzsyncro (Bill)
Observers who will be watching are:
1. Norman
2. TDICa (Mike)
TBD:
1. NewTdi (Andrew)
2. Peter Pyce (Peter)
Hesh
La Honda, CA USA
Any luck getting the rpm pickup device working?
And... how do we get results? If I bring a USB memory stick, can the data be put on it, so I can make my own excel graph?
Chris
tdi369
bay area, ca
1999.5 golf white
Dlai: i did put in b216 last week and the power is great. i won't be able to make it for the staurday dyno for i will be in LA (spring break).
dlai
Hesh: Well, we're working on getting the piezo device. It appears that the device is on loan from Gary to Jeff at Rocketchip. Jeff has been notified that we need the device shipped to us for this weekend, so we're waiting for him to ship the device. The man had better come through or else we'll have to rethink this GTG. In terms of getting your data, Ray can print out your runs, or give you a file. You might consider bringing a USB card reader so he can transfer the file to your memory stick.
TDI369: Great to hear you like the new power in your car. Sorry to hear you won't be able to make it...
KERMA
here
currently 99 beetle and 2011 335d
I think the best I can do right about now as far as the PP520 go, is to lend you guys the set from my own car. No other ones available. Guess I'll be stuck on stock power WRT injectors for a while.
peter pyce
Charlie, hold on, there is a slight possibility that the Dyno day may slip to a different (later) day. I hope is not going to happen, but as per today we are missing an important part of the puzzle and we do not know whether it will arrive in time.
KERMA
here
Keep me posted. I can red-label or express-mail them if I have to.
GassinGerhard
Santa Cruz Mountains, CA
Yeah, so I'm often outta the loop.
Anyway, My Danish .205s, or whatever they are, have about 60K on them. Do these things ever need cleaning? The originals had quite a bit of soot on them when I swapped them out.
I've still got my original .184s sitting in a box. Can I get new nozzles for them in the new and improved jumbo size - what is it, .216mm?
Peter Cheuk
Gasser :P
Daly City, Calif., USA
'06 Jetta GLI
Gary, the best you can do is go for a set of Kerma's PP520 or PP502's (the PP520's are the next step up from what you have now and the PP502's are another step from that). The Bosch .216's are actually .203 in diameter and it is believed that the power increase comes from the injector body design.
dlai
I got my new Kerma Kam installed and the car is running great! Tons of power 3k and above, and it pulls even harder from a stop now. Should be interesting seeing what kind of numbers the car is putting out now.
On a different note, I have a brand new Bora 4Motion valence for sale that I brought for my Jetta, but won't be able to use. Seems my FMIC gets in the way of installing this valence. I can bring it to the dyno day if someone is interested in buying it from me. Peter P. has one installed on his car and it looks great. I'm looking to get what I paid for it, $78.
bogstomper
Woodland (Sac), CA
Passat, 2004, Blue Graphite
Dan, Remember the anti stress bar you mentioned?, If so I am interested. I believe you said it would fit on the A3 shock towers. Can you bring it on Saturday if you get the chance?
Thanks /images/graemlins/smile.gif
dlai
Actually, I'm thinking of a caravan, meeting at the Hillsdale shopping center in front of Sears at around 7:30am or so...
Peter Cheuk
Gasser :P
'06 Jetta GLI
A better meeting place would be in front of the Barns & Noble book store in Hillsdale, which is right at the corner of Hillsdale and El Camino Real. The best way to get there is to take Hillsdale Blvd. It's a big parking lot so it will be easy to spot people coming and going. Also, there's a Wells Fargo nearby (in case you need to get money for the dyno runs...).
peter pyce
Dan, the device will be here (should be here) tonight. Do you want to meet somewhere so I can pass it to you? Also, when are you meeting Ray for the tests? I have day off this Friday, so we can perhaps do a pre-dyno or at least meet and talk to him, etc.... let me know.
Drivbiwire
Zehntes Jahr der Veteran
Boise, Idaho
[ QUOTE ]
The whole concept of a fixed percentage drivetrain loss in evaluating chassis dyno tests is one of the most absurd things i've ever heard of in my experience as a powertrain engineer, and is the motivation behind this post.
First, a primer: energy (or in the case relevant to this discussion -- power) cannot be created or destroyed. Simple enough? Where then, does that power that is transmitted from the crank, to the wheels, and ultimately to the road, go? Most of it goes to friction and therefore heat.
Second, an illustration: For argument's sake, take a stock 90HP TDI, and we'll arbitrarily say that it has a 15% driveline loss. That means that the engine would be developing about 104HP (90/1.15) at the crank. The loss through the drivetrain was 14HP (104-90). Now, you do a bunch of engine mods without touching the drivetrain, and you now measure, say, 135HP at the wheels. Referring back to the crank, you get 155HP, but the loss through the drivetrain is now 20HP, a difference of 6HP, WHEN NOTHING HAS BEEN TOUCHED THERE!
Do you now see the absurdity of this concept?
Firstly, may I submit that 2WD vehicles with manual transmissions have very good mechanical efficiencies, as evidenced by the fact that 2 quarts of non-pressurized, non-circulating oil is sufficient to keep the entire transmission cool and lubricated. In fact, to attach a number to it, manual transmissions are usually over 90% efficient, and many over 95%. That implies a loss through the transmission of between 5.3-11%. Even the best automatic transmissions with lock-up TCs achieve between 80-85% efficiencies.
Secondly, may I submit that contrary to popular (mis)conception, flywheel weights, rim weights/diameters and tire type (should) have very little contribution to the HP numbers on a rolling road dyno. Heavy flywheels and rims act as inertial dampers but do not destroy or create energy, nor transform it to heat, as would have to happen to if it is to result in a greater or lesser HP value on the dyno. Tires will shed energy in the form of heat by the simple contact with the ground and also though the flexing of the treads and sidewalls, but this amount is negligable in the scheme of things that it is generally ignored unless you are an engineer for an OEM, race car team or tire manufacturer. More on inertia in a moment.
Thirdly, I hope the above underscores that an accurate measurement of drivetrain loss cannot be overgeneralized. For one, it is not constant across the entire measurement range within a given test. In fact, friction increases roughly linearly with speed. In automotive engineering speak, this is quantified by a parameter called the FMEP (friction mean effective pressure), and although it's is not called that, it is manifested in many engine graphs you may read without even realising it. Frictional losses are different at 2000RPM to 4000 RPM, etc., etc. You cannot, therefore, equate the drivetrain loss of a car whose engine is turning at 8000RPM at the maximum rated power to one turning at 4000RPM, because on the basis of the RPM alone, frictional losses at 8000RPM are roughly double that at 4000RPM.
That said, yes, it's true: gear selection when performing a rolling road dyno DOES have an impact on HP, but it is not usually borne in dyno results, because the difference is small and within the inevitable variation from test-to-test and also measurement error.
Further, engine/driveline design considerations mean that there is a wide variance in frictional losses between different cars; the comparison of mechanical efficiencies between manual- and automatic transmissions have already been discussed above. Cars with AWD, automatic trannies, and large-displacement/many-cylinder engines will tend to have higher frictional losses than small-displacement, 2WD, manuals.
Finally, The importance of "motored" or coast-down tests in a dyno evaluation is important and needs to be stresssed, because that is what accounts for your true frictional losses and balances the inertial "ledger sheet" of the different driveline components, including the wheels and tires. The energy that is absorbed in the form of inertia in the flywheel/wheels/tires, etc. is accounted for ("given back," to oversimplify) in this coast-down, and when doing a street (i.e. butt) dyno, also accounts for the very important aerodynamic drag.
[/ QUOTE ]
Originally posted by TDimeister
DB
dlai
Peter: Good news on the device. I've not scheduled anything with Ray yet, so this Fri would be good. Let me email him and see what his schedule looks like.
dlai
Kerma: The device has arrived, so the dyno day is a go. If you could, can you send the pp520's to my home address? I think you have it.
Many, many thanks!
Dan
dlai
Ok, here are some details for this Saturday:
We will have a caravan meeting at the Barnes and Noble in the Hillsdale Mall, 408 Hillsdale Mall, San Mateo, Ca, at 7:30 am. We will leave no later than 8am, since the dyno runs will start promptly at 9am. It will be about a 30 to 40 minute drive to the dyno place.
For those of you who will be meeting us at the dyno place, Dyno Lab is located at:
25 Beta Court unit N
San Ramon, CA 94583
(925)831-8240
For those who will be attending and staying through lunch, I need to know who will be bringing what for the potluck.
I'll start a potluck list here, please list what you will be bringing. As an fyi, Ray will providing pizza, but some of you may wish to bring something if pizza is not your cup of tea.
1. Korean chicken (Dan)
I'm guessing that we should be done with all the dyno runs somewhere around 2 to 3 pm, perhaps later if there is lots of swapping of injectors and ecus.
I know that there are a few folks who need to leave early, so make sure you post here if that is the case for you, so we can schedule you early in the day. I know that Jolene, Rudy, and Bill need to leave early, but if there are others, please post to let us know!
Lastly, our special guest will not be able to make it, but regardless, this should be an interesting, fun, and fact finding day!
Looking forward to seeing everyone there and seeing what kind of numbers we all put up!
Dan
Gary Miyakawa
Admin Emeritus
Roswell, Ga
1998 NB TDI
Guys,
Glad to hear it made it !!
Don't forget, Scotch bright to clean the injector line AND a spare 9v battery just in case !
Gary M
P.S. If someone shows up with a PD, your on your own... It won't work on a PD.
peter pyce
Dan, the device was sent and it is to arrive today, but I have not seen it yet. Perhaps later in the night. Anyway, I hope it will be here shortly....
Gary, do not worry, no one is going to show up with PD. I doubt there is one in 200 miles range from here....
ChugBug
Oakland, CA
2000 Beetle
I do not get out of work until 8:30am and so I guess I'll be meeting everyone there. If whoever is second on the list wants to trade with me, that's ok. I just need to be out the door by 10:30 to 11am for a shoot in richmond. Not sure if I'll make it right at 9 and I don't want people waiting around for me /images/graemlins/smile.gif i won't be able to stay for the potluck though. I CAN show you my new beretta over/under tho:)
jolene
KERMA
here
[ QUOTE ]
Many, many thanks!
Dan
[/ QUOTE ]
It's a little too late tonight, but I will get them together tommorow. If can get to Fedex by 7:00 or so they will be there Thurs, otherwise Fri. Are you there during the day?
Now I just need to figure out what to run for the "opening day" test'n tune Saturday at the local NHRA dragstrip.
BTW these will be the old style pre-'03 connectors on #3...
I also have an switchable Upsoluted ECU with stock and big injector programs. It will work on Immo 1, that is pre-'02 if anyone is interested. My "spare" ECU came fedex today, can't wait to try it out, it has a certain other (for now) unnamed tuner's wares in it... /images/graemlins/cool.gif BUt maybe that throws to many variables into the mix. After all, you only have one day to do all the testing.
Dan, I don't think the cam will add any power but maybe it will, who knows. THe real story is in the torque curve, too bad there is no baseline for that. That is what you are feeling in SOP. I really need to degree it on the dyno. Maybe I will get a chance to use the EDGE dyno because a guy there wants a TDI in the worst way so then we can play. FUN!
dlai
Kerma: I'm home all day Thurs, but at the dyno place on Fri, unless it arrives in the late afternoon. Or, perhaps to make sure, we could ship it directly to the Dyno Lab, attention Ray Razon. That might work better, so we don't have to worry if anyone is home or not. His address is posted a few posts above this one.
I figured as much about the hp. I agree, it's probably the torque I'm feeling or some monster trying to get out of my engine! Yeah, too bad I didn't get any torque numbers as a baseline, but that makes me wonder even more now what my torque numbers will be on Sat.
That's great the connectors are pre 2003. Makes it much easier to hookup, since it's one of the older TDIs we're probably going to use.
We could test the other programs as well, time allowing. The advantage here is that Ray is a friend so I'm sure he wouldn't mind if we ran some extra tests, so to speak...
In all, I'm really looking forward to all the dyno runs!
Peter Cheuk
Gasser :P
'06 Jetta GLI
For the potluck, I will bring sodas and water.
I plan on being there the entire time so when I go on the roller is not a big deal. Also, since my wife is working that day, I will have my kids with me.
