What's it worth? Private and trade.
2006 Golf TDI BEW 5 speed manual, midnight blue.
220,000 km
VNT-17 under one year ago
Koni Reds, Kerma TDI springs and a 1" lift, roughly a year ago.
DG Sigma 5 shifter
SBC Stage 2 daily clutch with 14 lb SMF
Heavy aluminum skid plate from user volksparts. Monterey 15" alloys and new Pirelli P4 tires.
Brakes all 4 corners last year (I am harder on brakes, though...)
4 new glow plugs.
Brake fluid just flushed.
Bluetooth single DIN aftermarket radio + cheap extra gauges. Have original radio also.
Needs:
fenders (pre-approved for rust recall, just not done yet).
TB/WP
camshaft and lifters (replaced 2011, but I'm starting to hear thump-thump-thump)
ECU tune to match new turbo (drives, but surges...)
Fuel filter
Lift pump (didn't prime fuel filter well last time around)
Front pass door lock module/wiring (locks and unlocks manually only)
Rear wiper motor (washer tube seized/leaking)
Rear hatch latch motor (see leaking rear washer above - hatch opens with key only)
Wiper control module/hatch wiring Front wipers stay on permanently unless fuse for rear wiper is pulled then they work normally
Potentially a starter - it's original.
Valve guides if it ever needs a head job - blue plume of smoke every time it fires up after sitting off for a while. More than the usual puff, but still innocuous...
5w40 Rotella T6 run exclusively since the original cam change, oil changed every 6-8 months regardless of mileage (most maintenance has been due to time vs mileage; short commute for a diesel all its life).
Refundable deposit is down on a bought-back 2015 6 speed TDI GSW Trendline with under 50K on it (and priced about 3-5k below other similar offerings). It's pretty immaculate, and I like it equally as much as my Golf (maybe even more, when you factor in the ride/handling and the room) but I'm really debating keep & fix mine or sell/trade and buy up. If I did all work myself, keep is dead-nuts no-brainer, but I don't have much free time for DIY anymore. At the same time, I worry about the complexity of the Mk7 and what that means down the road, and car payments either suck or just plain suck.
Anyway, let's start with "what it's worth" and go from there...
