Roger thatJoe,
Thanks...status of my car is that is is sitting on a trailer in my driveway and not operational.
-Rob
I personally like 8oz of Howes every tank. I use 2oz of Meaner Kleener and 8oz of Howes lube every tank. Did this in my 06 and have continued to do so in my 09.tdiatlast, I am thinking of using an additive, any word of a good one? Battery is like new, took it to AutoZone and they charged it right up.
Be sure to report in the NHTSA website.Year: 2010
Build Date: 07/10
Make/Model: VW Jetta TDI Cup Edition
Tranny: DSG
Mileage: 56,866 at failure
Diesel Fuel Source: Misc including Chevron, Shell, Unocal 76, Valero--majority Propel HPR for last 9-12 months
Additives: Yes, Stanadyne Lubricity
Problem: HPFP failed
Dealer: VW of Vacaville (California)
Status: Dealer fixed under warranty
Everything running normal until limp mode with flashing glow plug/CEL. Fortunately one mile from home and made it to driveway. Turned off engine, tried to restart and engine just turned over & over...no attempt to start. Towed to VW dealer. Fuel contaminant test was clean--repaired under warranty.
Hey guys so it happened to me! Here’s the info
Year: 2011
Build Date: March 2010
Make/Model: Golf TDI 4D
Tranny: 6M
Mileage: 122,860
Diesel Fuel Source: Chevron
Additives: No
Problem: HPFP failed, metal shavings all over including filter
Dealer: VW Riverside and Ontario
Status: Fixed, paid out of pocket
6/12/15: driving with my 12 y/o brother to Stater Bros, speeds about 40 mph, moderate traffic, glow plug light comes on, loss of power, limp mode, and then car completely shut down. No control of the car whatsoever, hazards on immediately, emergency breaking the whole time. Hook up vagcom: HPFP and low pressure rail sensor. Get it towed home, contact vwoa, they deny case due to not having fuel guard installed. Called them again 3 times, asked to speak to a manager, get denied again! I filed complaints through BBB and NHTSA, but no luck. After 4 months of the TDI sitting in my garage and doing research, decided to buy new HPFP pump, injectors x4, and filter. (HPFP and injectors have 1 year warranty through VW).
10/2015: Tech does an amazing job on cleaning the whole fuel system including the fuel tank. Now, manager at VW tells me to come back to do the fuel guard recall asap. Also, states that HPFP is unlikely to fail again and that I might just see a drop of mpgs. That being said, God forbid a HPFP failure happens again; would VW cover costs since they fixed it even though I bought the parts and paid for labor? I am considering of buying microns kit, I love this car but just worrying too much about it! I find it funny and sad that VWoA blames it on the contamination of the diesel. I always pump at Chevron. I’m an EMT and the company I work for always pump diesel on the ambulances from Chevron and never had a problem. I’m thinking of trading it in for a civic or lancer, I like the golf but VW really has let me down. Volkswagen of Ontario by far the best customer service, but not vwoa!
Question: is it possible that the HPFP can fail again as of today’s date? Wouldn’t they make some changes to the pump? Read on the forums that just some numbers on the model number change…
Thanks guys, these forums do help a lot!!
I don't remember his exact wording. "Deteriorated" or something similar more likely.So the car was drivable with a "destroyed" HPFP?
Don't forget to file with the NHTSA.I don't remember his exact wording. "Deteriorated" or something similar more likely.
Are you trading for new or used? I have a base Golf now, but a Mk VII with TSI and so far so good.Ok guys I'm back.
Driving home, 325 miles after new HPFP and injectors installed, glow plug light starts to beep taking off in first gear, car goes into limp mode. Pull over safely, turn off the car and starts back up. Check to see if there was any shavings on the pump and it clears. Few hours later, I take the car up and down the block and no light or anything, like it never happened. I am waiting on my friend's vagcom, I am so concern now!
Going to be trading it in for a golf base model (no tdi) or maybe a civic this weekend. Any bad stuff regarding the mk6 golf base model? I will be doing research on it soon.
Thanks lads.
SOP for VWoA is now to require that a fuel sample be tested. VWoA won't assume anything, although I've yet to read here about anyone whose sample came back positive for contaminants. You should be okay.... They came out and said the HPFP basically disintegrated and that they'd have to replace the entire fuel system (both pumps, injectors, fuel rail, filter, and all the lines all the way back to the gas tank) along with draining and cleaning out my gas tank. They told me it would be covered by warranty and sent me on my way with a loaner.
Dealer: Stokes VW in North Charleston SC
Status: Pending. When they originally diagnosed it, they said it would be completely covered by VW warranty. Called them yesterday (10/14) asking for an update and they said they said they just sent a fuel sample off to VW and are awaiting those results before they do can do any work.
If I'm 100% positive I put diesel in it (and trust me, I am), is there any way that this won't be covered by VW? What would the conditions be? And at that point what would my options be?
that was my basic solution, haha... that way I have the same word for my gassers...Or just say fuel tank....
Be careful referring to your "gas tank." It's tough to say "diesel tank", but sadly, it does make a difference in perception.
Yikes! Hoping this isn't the case ... I've never had an issue with Sunoco diesel before - and I know every fuel station and every pump is always different - but hoping this was just a freak accident with my HPFP and that it ends up being all good in the hood.If VW comes back with a bad fuel sample, then you will be responsible for the complete repair. You can try to push the dealer and VW but from previous posts, you will have limited success.
