cujet
OK, my 06 has been suffering from random bad MPG. And, for the most part, staying lower than normal lately. But running just fine. So, a suggestion from a fellow TDI forum member was to check for dragging brakes.
I checked the rear pads and the LH side was flat worn out. The RH side was just fine, with nearly new pad material levels. (I did purchase a new set of OEM pads).
I found the LH emergency brake partially activated. The caliper spring won't pull the E-brake to the OFF position.
In a rush today (got a road trip today), I took a section of bicycle chain and a cotter pin and hooked this around the lower shock mount. I attached a turnbuckle and a very strong spring. This pulls the E-brake cable back to the OFF position every time. Just like God intended. In actuality, it looks like the nicest rig you have ever seen, 4" of chrome shimano dura ace bike chain, aviation turnbuckle, stainless cotter pin and all.
I suspect 100% satisfaction on my trip. I'll bet MPG goes back up to normal!
Chris
Chris
