OEM HID\'s and Headlight Sprayers installed! *PICS
[ QUOTE ]
Kennedy said:
Occam, please do share...
I annhialated mine, extracted all the pins, then replaced the whole thing. I still haven't completly re seated the block fo fears I may have to that again!
[/ QUOTE ]
I got a relay block from IMPEX so I could see what I had to deal with BEFORE I got upside down under the dash.
The relay block is held together with "hooks", (for lack of a better term), on each of the four corners of the pink interior.
When you have the relay block apart you can see that the four "hooks" of the pink part are in the shape of a ramp and when you put the block together they "click" into place against cooresponding hooks on the inside of the black main relay block.
So how do you get the "hooks" to disengage so you can take the darn thing apart. Small, (jewlery), screwdrivers are a pain in the arse and are very hard to handle. /images/graemlins/confused.gif
The trick is to create a "ramp" to pull the sides of the block apart so as to allow the "hooks" to disengage. /images/graemlins/ooo.gif
I did it by taking an AOL CD box, (the plastic ones), and cutting 4 rectangles of the correct size to fit the relay box cut outs, (just measured 1/2"). To make it even easier cut the "ramps" out of the hinge side of the box. That way they will already have a bevel. /images/graemlins/cool.gif
Place the 4 "ramp/spreaders" in the slots between the black relay exterior and the pink interior the closest to the edge as you can. The bevel should be on the outside edge.
Once the ramp spreaders are in place a bit of judicious jiggling should cause the hooks to release and you can then carefully pry, (the black part is soft), the two apart. /images/graemlins/shocked.gif
When I did it in the car the ramp spreaders released the hooks and the relay block "popped" the slightest bit, enough to insert a flat blade between the two parts to separate them completly.
The relay block I got from IMPEX was a bit hard to separate but the one in the car practically fell apart in my hands with this trick. /images/graemlins/rolleyes.gif
YMMV /images/graemlins/grin.gif
Occams Razor
