Stock torque of the engine is 177lb-ft. Even a slight power increase will make it slip, so I would guess MAYBE 200lb-ft if you're lucky. They are terrible clutches.
Why are they terrible? Because they won't withstand modifications that deviate away from the original intent as the car was designed/produced?
Okay, MINE is terrible.
Even without modifications, the clutches on some of the higher horsepower PD's like the PD130 and PD150 are prone to slipping problems. This shows that they are a weak point in the TDI drive train.
Also, another point that supports my "terrible clutch" comment is that the previous TDI's (3rd generation) don't have slipping problems with reasonable power upgrades.
Quote from dieselgeek website:
"Our performance clutches replace the dual mass flywheel with the earlier time-proven single mass flywheel and clutch kit of the Corrado G60 and VR6. The Passat TDI and Jetta III TDI come standard with these parts and have no issues with slipping, even with several power increasing modifications."
Also, they describe the 4th generation TDI clutch as "weak."
It's a known issue that they are "terrible."
