Search rendered no accurate results.
I recently acquired an 05 bhw TDI. Malone stage.
Driving today, seemed like the turbo was louder, lots of air noise, sounded like a substantial boost leak. Broke out VCDS and measure actual vs requested boost... It differed by about .8 bar then I got the codes P0299 and P010 when testing.
I inspected the charge pipes and noticed the one directly off the turbo is quite loose, not disconnected and the surrounding area was damp from oil blowby I assume.
Question.
1. If I'm seeing damp spots around charge pipe connections...there's a leak right?
2. How loose are these OEM connections typically?
3. These are O-ring sealed correct? Is there a kit out there to replace them all in our cars?
Thank you!!
Question.
Thank you!!
