OEM B7 NMS Passat Mud Flaps are here!
Status
Not open for further replies.
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
The OEM Mud flaps we have all been waiting for are finally here.
They retail for $60 per set (one front set and one rear set per vehicle) and my online price is $48 per set.
Click the pictures to be taken to the order page.
vlsi54199
PA
2009 Jetta TDI, 6M, Candy White
Installation?
any instructions or I have to take off the tires?:confused:
thanks!
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
Upon looking at the instructions, both sets say to remove the wheel for installation.
It may be possible (as has been with previous models) to install the front mud flaps without removing the wheels.
But the rear will necessitate removal.
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
I can now say from personal experience that it IS possible to install the front mud flaps without removing the wheels, but not the rear.
On the front you will have to turn the wheel to full lock (easiest to hold there if you have an assistant or a strap of some sort) then you will have just enough room to drill the wheel well liner.
There is no way around the rear since you can not turn the wheels. You will have to remove them to drill the liner.
Fixmy59bug
Henderson, NV
2015 Passat TDI SE
We have had a number of people buy them and hopefully install them by now...
Would anyone mind giving their own review of the install process and overall fit and finish?
Status
