tassolake
I'm having an odd BRM issue with the car dropping into partial limp mode (It's not full limp mode). I've owned this car since new and replaced the lifters / cam / tandem pump / turbo / lift pump / timing belt / cylinder head all in the last 100K km (60K miles). Car now has 320K KM (200K miles).
Symptoms:
Lots of white smoke on start up.
starts and idles great
During hard acceleration the car appears to drop into limp mode (minimal power), continue to gently accelerate and the car then behaves normal again (without turning ignition on or off) and will get upto 130km/h (80mph), whereas in the past limp mode would limit me to 80km/h (50mph). Sometimes on the highway it loses power, then regains it.
VCDS does not show any error codes (other then AC compressor sensor shorted to ground).
Checked the Cam and Lifters last night (they appear good with a very slight flat spot on 6 of the 8 lobes). Lifters do not appear to be dished.
Group 13 shows the following injector deviations, 0.00mg, -0.28mg, -0.89mg & 1.15mg (cyl 1 - 4).
Are those flat spots on the cam enough to cause this issue?
Could this me a leaky injector issue (suspect cyl 4)? causing the O2 sensor to back off the fueling when it detects it being rich? Is there something else I should check?
Any guidance would be much appreciated.
Symptoms:
