DownByTheRiver
Car is feeling festive, as lights are on galore....ABS, ESP off, Airbag, TPMS, steering wheel light.
Figured it was an ABS sensor, but VCDS doesn't show anything since 2016 regarding that. Am I looking at this log correctly?
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A30CC055077 Mileage: 154630km-96082miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9982
Revision: 71H21--- Serial number: CVN: D240C61F38D3FF82
Coding: 001D0012042400008000
Shop #: WSC 05015 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B5BDB1EB2589C5154-806E
VINID: 0669D37874430134C01450071C8424B195
4 Faults Found:
12642 - Charge Air Cooler
P026A 00 [104] - Efficiency Below Threshold
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 154385 km
Date: 2021.12.22
Time: 14:23:18
Engine RPM: 1910.50 /min
Normed load value: 0.0 %
Vehicle speed: 102 km/h
Coolant temperature: 100 °C
Intake air temperature: 46 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.100 V
Unlearning counter according OBD: 39
Air mass at air mass meter 1: 122.0 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 123.7 °C
Outside temperature: 18.5 °C
Intake air temperature before throttle valve: calculated: 28.2 K
Sensor for temp after charge air cooler: raw value: 45.9 °C
Coolant pump for charge-air cooling: spec. value: 95.00 %
25280 - Reductant Metering Module
P20FE 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
5253 - Particulate Filter; Differential Pressure Sensor
P2452 00 [032] - Elect. Malfunction
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 057 P HW: 02E 927 770 AT
Component: GSG DSG AG6 541 9435
Revision: 06454104 Serial number: 00002007060262
Coding: 0000020
Shop #: WSC 04960 001 00001
VCID: 266D1A6A91DA31B91B-8072
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 1
Mileage: 154558 km
Time Indication: 0
Date: 2016.05.15
Time: 10:19:26
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492700FFA30B03EB92200042A71000
Shop #: WSC 09003 957 00200
VCID: 7DDF1506E4CC52612A-8028
6 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 154017 km
Time Indication: 0
Date: 2016.05.09
Time: 12:43:37
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 72
Count: 49665
Count: 1
Count: 512
Count: 0
03842 - RPM Sensor Rear Right: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 174
Mileage: 154118 km
Time Indication: 0
Date: 2016.05.10
Time: 09:29:02
Freeze Frame:
Count: 0
Count: 12
Count: 12800
Count: 87
Count: 50432
Count: 64768
Count: 256
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 7
Reset counter: 175
Mileage: 154128 km
Time Indication: 0
Date: 2016.05.10
Time: 12:12:58
Freeze Frame:
Count: 1088
Count: 0
Count: 4608
Count: 83
Count: 48640
Count: 1
Count: 1030
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 135
Mileage: 154597 km
Time Indication: 0
Date: 2016.05.16
Time: 15:32:07
Freeze Frame:
Count: 16387
Count: 13
Count: 4096
Count: 128
Count: 34048
Count: 0
Count: 511
Count: 14848
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 130
Mileage: 152746 km
Time Indication: 0
Date: 2016.04.20
Time: 17:53:27
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 16390
Count: 48640
Count: 1280
Count: 1021
Count: 0
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 10
Reset counter: 135
Mileage: 152746 km
Time Indication: 0
Date: 2016.04.20
Time: 17:53:17
Freeze Frame:
Count: 16387
Count: 12
Count: 12288
Count: 88
Count: 41216
Count: 1473
Count: 1019
Count: 4864
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0161776323
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 3449F0229F06532995-8060
1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 22
Reset counter: 173
Mileage: 140545 km
Date: 2021.07.11
Time: 11:38:20
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1C1938821796FB69BD-8048
3 Faults Found:
9473137 - Motor for Left Temperature Flap
B108C 71 [009] - Actuator Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 136
Mileage: 128504 km
Date: 2021.02.06
Time: 14:31:14
9473393 - Motor for Right Temperature Flap
B108D 71 [009] - Actuator Stuck
Freeze Frame:
Fault Priority: 2
Reset counter: 136
Mileage: 128504 km
Date: 2021.02.06
Time: 14:31:14
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator Stuck
Freeze Frame:
Fault Priority: 2
Reset counter: 152
Mileage: 141299 km
Date: 2021.07.22
Time: 11:03:54
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0164
Revision: BL121001
Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
VCID: 74C93022D786132955-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250112 05 54 0403
Coding: 22300A
No fault code found.
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01FF18
Coding: 00004D48
Shop #: WSC 45296 003 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FC33F4EB6A030F1A8-803A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000B70X0L
Coding: 303047
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME40624466ZZZP
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME31136566ZZZP
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME59260316ZZZL
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME22491A16ZZZP
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME5C667B14ZZZ3
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME015B7B14ZZZZ
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 136
Mileage: 152746 km
Date: 2021.11.28
Time: 17:53:34
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110521100259
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF1506ECCC52612A-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 1A153E9A1DA28559AF-804E
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 25011201290572
Coding: 461000
VCID: 3D5FD506A44C92616A-8068
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AF52E5A8D42D5D9FF-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000282846005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E7DE24A712A79F9E3-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661436174
Coding: 010000
VCID: 2977115640C41EC136-807C
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000020413770
Coding: 00581B0000000000000021010100202020202120202020
VCID: 60E14C72737E9F8921-8034
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
Component: RNS-MID H61 3690
Revision: AB001001 Serial number: VWZ6Z7M4019165
Coding: 04090002010000A6000B
VCID: 2D7FE546742C02E1DA-8078
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Reset counter: 136
Mileage: 128496 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0003841856
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 290 3301
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 354FCD265C7C4A21A2-8060
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 23
Reset counter: 176
Mileage: 154561 km
Time Indication: 0
Date: 2016.05.15
Time: 10:50:19
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 31.0°C
RPM: 1779 /min
Speed: 15.0 km/h
Speed: 15.0 km/h
Count: 0
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0000902
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
VCID: 65EF5D66645CFAA1D2-8030
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FC33F4EBEA030F1A8-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011131401045
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0003768212
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D1F35860C8CF2614A-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 136
Mileage: 128496 km
Time Indication: 0
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661550472
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2773176E5ED028B120-8072
End-------------------------(Elapsed Time: 03:33)------------------------
52 56 62 72 77
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 154385 km
Date: 2021.12.22
Time: 14:23:18
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 1
Mileage: 154558 km
Time Indication: 0
Date: 2016.05.15
Time: 10:19:26
Revision: 00H31001
6 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 154017 km
Time Indication: 0
Date: 2016.05.09
Time: 12:43:37
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 72
Count: 49665
Count: 1
Count: 512
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 174
Mileage: 154118 km
Time Indication: 0
Date: 2016.05.10
Time: 09:29:02
Freeze Frame:
Count: 0
Count: 12
Count: 12800
Count: 87
Count: 50432
Count: 64768
Count: 256
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 175
Mileage: 154128 km
Time Indication: 0
Date: 2016.05.10
Time: 12:12:58
Freeze Frame:
Count: 1088
Count: 0
Count: 4608
Count: 83
Count: 48640
Count: 1
Count: 1030
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 135
Mileage: 154597 km
Time Indication: 0
Date: 2016.05.16
Time: 15:32:07
Freeze Frame:
Count: 16387
Count: 13
Count: 4096
Count: 128
Count: 34048
Count: 0
Count: 511
Count: 14848
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 130
Mileage: 152746 km
Time Indication: 0
Date: 2016.04.20
Time: 17:53:27
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 16390
Count: 48640
Count: 1280
Count: 1021
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 10
Reset counter: 135
Mileage: 152746 km
Time Indication: 0
Date: 2016.04.20
Time: 17:53:17
Freeze Frame:
Count: 16387
Count: 12
Count: 12288
Count: 88
Count: 41216
Count: 1473
Count: 1019
Count: 4864
Coding: 130C0C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 22
Reset counter: 173
Mileage: 140545 km
Date: 2021.07.11
Time: 11:38:20
Revision: 00001001
Coding: 0010001012
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 136
Mileage: 128504 km
Date: 2021.02.06
Time: 14:31:14
Freeze Frame:
Fault Priority: 2
Reset counter: 136
Mileage: 128504 km
Date: 2021.02.06
Time: 14:31:14
Freeze Frame:
Fault Priority: 2
Reset counter: 152
Mileage: 141299 km
Date: 2021.07.22
Time: 11:03:54
Revision: BL121001
Coding: 22300A
Coding: 00004D48
Coding: 303047
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 136
Mileage: 152746 km
Date: 2021.11.28
Time: 17:53:34
Coding: 000A140000
Coding: E20000
Coding: 231E01
Coding: 461000
Serial number:
Coding: 000007
Coding: 010000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 136
Mileage: 128496 km
Time Indication: 0
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 176
Mileage: 154561 km
Time Indication: 0
Date: 2016.05.15
Time: 10:50:19
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 31.0°C
RPM: 1779 /min
Speed: 15.0 km/h
Speed: 15.0 km/h
Count: 0
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 136
Mileage: 128496 km
Time Indication: 0
ROD: UHVNA.rod
