minilooker
Hi anyone tried installing NOS system with their TDi? I'm was thinking if its possible and what would be the disadvantage if I would install this thing as part of my diesel performance plan.
Good call. My old IC system used to have in inject about 3 feet before the intake, and that distance used to sometimes cause the engine to judder if I tried injecting it a little early. That "feeling" of when is right is probably pretty much on full boost, so for me might be about 2750-2800rpm when the car is probably getting in its stride.If you have a lot of NOS flow and inject too early it can stall the engine, never had a major backfire. I always try to inject just before peak boost. Keep an eye on those spikes!!
In the NX promo video linked above the guy mentions using N20 sparingly at low RPM to minimize turbo lag. Kind of a stop gap O2 delivery system while the turbo spools up. Have any of you messed around with that? I keep thinking that one day I'll upgrade my current ALH with a 2056 or 2260 but am scared the lag will be unacceptable. If N20 could go towards solving the lag issue I'm all ears.
Mine was 315 with 290 without (BHP not WHP)How much HP you're normally get when you're TDI is a bit smokey say AFR 1.:15
Around 30 HP maybe ? When you're use NOx
Out of interest what increase did you see with Propane?I used to run propane but the more my car was used on trackdays the more I realised lugging about the tank and gas was hampering me more than the gains, so I just got big nozzles.![]()
