TDIpower01
What nozzles would recommend for stage 2 Malone tuning on 2001 vw jetta tdi 1.9 alh? And would my stock clutch be ok
My stock clutch couldn't take a stage 1 tune, ended up using the Luk Repset. Now with my stage 2 tune, .216 nozzles, and an S7 turbo, it's still holding. The euro 110 engine uses the .205 nozzles with the stock turbo. Are you planning a turbo change or keeping the stock VNT15?What nozzles would recommend for stage 2 Malone tuning on 2001 vw jetta tdi 1.9 alh? And would my stock clutch be ok
I'm planning on keeping the stock vnt15 and I currently have a stage 1 tune that my original stock clutch is still holding. But thinking about it a stage 2 will probably kill my original stock clutch.My stock clutch couldn't take a stage 1 tune, ended up using the Luk Repset. Now with my stage 2 tune, .216 nozzles, and an S7 turbo, it's still holding. The euro 110 engine uses the .205 nozzles with the stock turbo. Are you planning a turbo change or keeping the stock VNT15?
Okay so I can do a stage 2 with stock clutch and nozzles but won't get the full performance of the stage 2 without upgrading nozzles? Also my clutch has approx. 255,000 milesStage 2 tune with stock nozzles won't kill it, unless it's already near the end of its life. ToxicDoc's Luk Repset isn't much, if any, stronger than a stock clutch and he says his is doing fine with tune and nozzles. Stock clutch will hold a strong Stage 3 tune with stock fueling.
