jpg98
Hello,
My 2014 Passat is out of warranty now and I'm having an issue with the Nox sensor. I have code U100600 NOX Sensor 1 Bank 1 No communication.
I purchased a new sensor/controller and it's still doesn't seem to be working. NOX Sensor Bank 1 Sensor 1 shows 65535 ppm at all times.
A check of the wiring found voltage on the appropriate pins of J583 on the NOX controller and I verified the signal connection pins (3&4) back to the ECU.
Any suggestions? I suppose it's possible I received a bad part, but it is an OEM sensor.
Thanks.
Thanks.
