myribitsbroke
Good afternoon,
I have read many posts over and over regarding this issue. I am trying to do everything possible to avoid a dealership visit as I am, of course, out of warranty.
I have a P2BA6 (NOx exceedance) and a P1A58 code (NOx regen required), which lights up the DPF and MIL. I had the DPF replaced under warranty about 30k miles ago. Also had the thermostat, catalytic converter, and cold weather intercooler kit installed about 25k miles ago under warranty, and during both of those warranty visits the EGR valve was cleaned. A few short months after the last warranty service, DPF and MIL came on with aforementioned codes, and of course I am now out of warranty. I brought it to my local VW shop, they performed a forced regen which cleared the DPF light for about 10 miles before it came back on, and they said that the P2BA6 was a "dealer code" that they couldn't figure out?
I also occasionally have the DPF light off, with flashing glow plug light. I also popped a P0299 and a P0638 a couple days ago which have cleared themselves out.
Yesterday, I performed an oil change and swapped out the glow plugs. I also checked the throttle valve, and that looked nice and clean. After all my extensive research, I used my OBDELEVEN to manually start a NOx regeneration (channel 18) and drove for over an hour in each direction. No codes cleared.
But, I am not sure I performed the NOx regen correctly. I changed the value to 0001 and it said function not available. I returned to the screen, and the value had indeed changed to 0001 from 0000, so I assumed that meant the NOx regen was active. The soot level was 0.9, then dropped to 0.6, 0.3, then 0. The NOx load stayed constant at 15.97 the entire drive, and this value has not changed in quite some time. After the first hour and ten minutes, I pulled over to stop and re-start the car. Still had codes. Set value to 0001 again, same thing as before, still codes. However, this time the soot number jumped up to like 19 or 20, then started to drop, quickly at first, then slowly until it got down to 0.3 again.
When opening channel 104 on Live Data, I had at the top 0xFF02 done(or something like that, I should've taken a screen shot.) Value 1 said 0xFF01, value 2 0xff02, and values 3 and 4 both 0000000. None of this changed at any point during my drive. I have no clue what any of those mean.
Then, when I got home I had another code (P2459) which is now gone.
So, I am not sure if I correctly performed the NOx regen, and if I didn't, I guess I don't know how to.
Also, I checked to make sure engine temps were not dropping below 87C which they did not so I think the (new) thermostat is OK.
My goal is to get the car to be able to pass emissions and then get a delete kit from rawtek, which is an expensive job in itself, so if I could get the codes cleared for even a day or two to pass inspection....
So, if anyone has any advice I'd greatly appreciate it. If not I might have to wave goodbye to this car
