• Server migration complete
    In the early morning of September 26, 2020, our migration to new servers was completed.
    Things seem to be working as expected, but if you notice any issues including not receiving email notifications,
    please vistit this thread for more details
Not much heat
ejm4
PA
2014 Passat TDI
2014 Passat w/ 26k miles, first chilly morning today in Central PA (41 degrees) and the car got up to 190 degrees, but I had very little warmth coming from the driver side vents and nothing from the passenger side. I tried changing the air flow designations, but it did not change anything. Could this be the famous heater core issue?
mattbevans
Murfreesboro, TN
2013 Passat TDI SE
Sounds about right. You might even throw an EGR CEL soon too because of it. All covered under emissions warranty with a loaner provided. Newer cores should be ok as the originals had too much flux from manufacturing. They are also supposed to flush the system twice so make sure they do that. Look up TSB 80-16-01.
Unfortunately it appears that the engine in your car, when the dieselgate fix is applied, can boil coolant during regen and plug the heater core. That may be the problem now, and it may happen again. Since you have the warranty and the heater core replacement on your car isn't a huge deal, that may be OK. If it were my car I'd get it tuned to take that risk away, but then you may void the emissions warranty if the dealer discovers the tune. Damned if you do...
ejm4
PA
2014 Passat TDI
Thanks - dealer appointment scheduled for next week.
mattbevans
Murfreesboro, TN
2013 Passat TDI SE
Has this been documented or is this just speculation? Not sure this makes a ton of sense. Mine plugged at around 50K and had the fix done at 49K and this issue has been going on before the fix. Not trying to be confrontational just curious.
Not documented. NMS Passats have had a lot of heater core issues, both before and after the fix. Some say the original issues were because of poor manufacture of the cores, but the issues have persisted. We have customers who report 2 and 3 core replacements. The CKRA engine was difficult to fix, it took multiple attempts for VW to get a fix that the court would accept, and they never were able to provide a satisfactory fix for the manual transmission Passats (not including the '15s, which have a different engine). Mechanics have seen evidence of boiled coolant in a number of cars, and believe it can plug the heater core.
mattbevans
Murfreesboro, TN
2013 Passat TDI SE
It is certainly a plausible explanation when you look at the coolant circuit but this generally applies to all the 2.0 TDIs. Have there been issues with the other fixed models? I know the engines are a bit different but looks like the principal is the same. It seems like some of these issues could be the cars having sat around for a few years and not being run caused some of these issues especially when you have excess flux causing the coolant to become acidic. I'm definitely going to keep my eye one this issue.
Engines are apparently enough different. The CKRA has a smaller turbo, fuels at different pressures, and is also moving a heavier car. For whatever reasons it allegedly causes higher coolant temperatures. It also has a different thermostat, and many people here have reported Passats running significantly hotter than other CR TDIs.
06bluebeetletdi
Middlesex, NC
My passat has had the heater core replaced twice, at 41,000 miles in December 2015 and at 53,000 miles in October 2017, fix was done at 50,000 miles in September 2017 (it sat most of the 18 months 3/16-9/17). As far as coolant temps, my 14 passat is normally 211-215, sometimes as high as 221 (upper 90s air temperature + regeneration), my 13 beetle is usually 186/190, max 197.
06bluebeetletdi
Middlesex, NC
Coolant temperature of my passat is close to the oil temperature of the beetle, I can’t imagine how hot the passat oil temperature must be (good thing it doesn’t have an oil temperature sensor).
TDI-EMS
minnesota
2014 passat tdi dsg
for what it is worth, i had my heater core replaced under emissions warranty. To date it completely fixed my heat problems. it was done about a year ago and i have had 18K miles since. currently at 98000 miles on my '14 passat se
ejm4
PA
2014 Passat TDI
UPDATE:
Dropped the car at the dealer the evening before the appointment. The next morning I received a text with a video link from the tech assigned to the car. The video showed the the heater core needing replaced and they stated the cause was due to left over / residual debris left in the engine from assembly - ***... LOL
The car has 26K miles on it and they then wanted to sell me a 60,000 mile service due to TIME not mileage. They also stated in the video that if I don't replace the engine air filter, there is a good chance my DPF will fail...
Needless to say, I did not bite on the service or the air filter change as they were performed at another shop. I did let them sell me a brake fluid flush.
mattbevans
Murfreesboro, TN
2013 Passat TDI SE
Glad you are up and running again. I am always hesitant to let someone else wrench on my vehicle but it is hard to pass up warranty work. Often times I find that while people may know how to fix things they don't understand the actual engineering behind the design and so you get them saying things like "left over residual from assembly" when really its excess flux from the manufacturing of the heater core. Some things do need to be changed based on time but mileage is more than likely an appropriate time to do things like oil, air filter, etc.
Did they happen to flush the coolant system a couple of times? They are supposed to do that or you risk this happening again.
Tom in PT
Twilight Zone, WA State
When I had heater core replacement done (warranty, at dealer) the dealer flushed the system 3 times. I believe the repair procedure calls for this.
