wilkius
Hey folks, I'm looking for ideas on where this noise might be coming from.
When I go over rough surfaces such as crossing an intersection, but not big bumps, I get what sounds like a tennis ball in a cup sort of sound. It's not metallic, but does feel a little hollow and could be like a knocking. I can't seem to get a decent recording of it.
I've just replaced my front struts, mounts, bearings, bumps stops, outer tie rod ends and sway bar links as well as the rear shock mounts and shocks (Bilstein B4 all around). The noise seems to have started after that replacement but as far as I can tell, everything is torqued. I checked my subframe bolts and sway bar mount bolts and they are tight. The noise started before I replaced the tie rod ends.
Sometimes when I hit a bump it will do the tennis ball rattle when the front hits AND the rear hits the bump. Other times, it seems to be more just the rear. I'm completely deaf in one ear and so I can't tell AT ALL where the sound is coming from specifically although it seems like if I go over bumps on the left side of the car the noise is more common.
Looking for ideas on what to check. It's been suggested I have a bad shock (that sounds a bit like the "log" thing that a lot of MK7 GTI folks have had) but the cure for that is Bilstein B4s.
I'm stumped and with all the torque to yield bolts, troubleshooting can get expensive so I'd like to have a laundry list of things to check to find this once and for all. Thank you!!
