no start
mx757
outside St. Louis Missouri Area.
2005 Jetta mk4 PD /2014 TDI Jetta Sportwagen DSG
2012 Jetta Sportwagen. just suddenly died after running fine. wouldn't restart had it towed home.
VCDS scan shows : removed fuel meter valve perfecly clean. opened fuel filter, also perfectly clean
short to ground?? found blown 15 Amp fuse in electrical box next air cleaner. no spare.
ordered new fuel meter valve and Glow Plug Control Module from IDparts today. they are out stock 2 weeks on Fuel Pressure Regulator Valve (N276 )and Valve for Fuel Metering (N290), so I wait... a not sure if that issues?
any suggestion?
battery is DEAD. its removed from car on on charger right now.
thanks.
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 26214 051 00000
VCID: 2F307A793B1B033226D-807A
VINID: 0E69DD70745A1D3746006081049B812877
4 Faults Found:
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 000 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 305466 km
Time Indication: 0
Date: 2025.03.25.
Time: 15:48:37
Freeze Frame:
RPM: 1219 /min
Speed: 11.0 km/h
Voltage: 13.53 V
Pressure: 32.0 bar
Inj. Quantity: 15.4 mg/str
Lambda: 27.6 %
Lambda: 33.9 %
000145 - Valve for Fuel Metering (N290)
P0091 - 000 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 305466 km
Time Indication: 0
Date: 2025.03.25.
Time: 15:48:37
Freeze Frame:
RPM: 1219 /min
Speed: 11.0 km/h
Voltage: 13.91 V
Pressure: 0.0 bar
Inj. Quantity: 18.4 mg/str
Lambda: 81.3 %
Lambda: 0.0 %
000897 - Glow Plug/Heater Indicator Circuit
P0381 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 19.8 C
Voltage: 11.32 V
Bin. Bits: 01000000
Torque: 219.0 Nm
Temperature: 21.6 C
001668 - Glow Plug Control Module (J179)
P0684 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 305466 km
Time Indication: 0
Date: 2025.03.26.
Time: 10:27:33
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 6.76 V
Temperature: 9.0 C
Bin. Bits: 00110000
Time: 2.52 s
Temperature: 10.8 C
Readiness: 0 0 0 X X
JETaah
mi 48836
Is that fuse in the engine fuse box (SB)14? or (SB)24
There should be the fuse numbers molded into the plastic or some way to identify the socket for them.
The Fuel Pressure Regulator Valve (N276) and Valve for Fuel Metering (N290) look to be powered by that fuse.
I'd unplug those two items, put a fuse back in and crank the engine. See if the fuse holds up.
There are other items on that fuse as well like a radiator fan, throttle control valve. Might try to unplug that, put a fuse in and give it a go. Clear your codes.
