No start
Fahrvegnugen
Burlington Vt
01 golf 1.9 alh gls silver
I went for a simple inspection sticker. It passed. Picked up after week of sitting. It was a cold weak battery with not enough to start. Boosted the battery and drove home and fully charged overnight. Drive to work next day, all good. Following morning no start. 5 year old battery, so new h7 battery replacement. Works good first day then no instrument lights no crank.
This lead me to replace the steering lock housing which I discovered had broken.
Go to work and return. Next day no cluster lights but cranks fine and gets immobilized. Battery at 85% and two codes.
- P1650 35 10 missing msg from cluster
- p1570 35 00 engine start blocked by immobilizer.
Is the little clip on the key tumbler all it would take to cause this? I’m not sure it’s locking tab is still intact.
Fahrvegnugen
Burlington Vt
I went and checked my work. Both the yellow clip to the steering lock housing and the black clip to the key tumbler are connected. Both 5 amp instrument clusters fuses are working. Is the instrument cluster broken?
Vince Waldon
Edmonton AB Canada
The pickup ring for the immobilizer surrounds the lock cylinder casing, and since the immob issue seems to have started after you were in the area I'd be inclined to go back and check around that area carefully.... accidental damage, broken wire, disconnected connector, etc.
Fahrvegnugen
Burlington Vt
Im having a big drain on battery now. My curiosities grow overwhelming. I could take alternator out for testing but I don’t imagine that would cause an immo issue. It was a good alternator before the battery boosting.
Fahrvegnugen
Burlington Vt
Got car running again but no dashboard gauges or lights worked. Just the clock and trip.
-Getting intermittent 18058 code for missing message from instrument cluster.
-01299 diagnostic interface for data bus no communication
-00849 s contact ignition/starter switch unknown condition
-00957 key 3 adaptation limit surpassed
The 4 door control module supply voltages are all too low…
It seems to be rejecting its new car parts so I gave the immo a tune.
I’m wondering if the new ign switch is causing the issue.
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Aftermarket or oem?
Fahrvegnugen
Burlington Vt
I couldn’t get instrument cluster to light up with oe ignition switch. Only clock and trip work. I didn’t unplug the cluster or mess with it, so I’m leaning towards a cluster replacement.
Anyone have a good cluster replacement? I will check some junk places before I go for any upgrades but I’ve always wanted an ambient temp gauge.
super1
NY
none
Does the Glow Plug Light come on when the key is in the ON position?
Fahrvegnugen
Burlington Vt
No but relay 109 is good. I tried two different gray 109s and both start the vehicle, I just wait for expected glow cycle duration before starting. Nothing on cluster works other than aforementioned clock and trip
Fahrvegnugen
Burlington Vt
I Sent the instrument cluster out for repair and it had nothing wrong with it. Put it back in and it worked like nothing happened.
Only thing I can imagine is a fuse didn’t have good contact. One looked a bit dirty but was lighting up fine when tested.
The end.
