smos1
So, its a 96 B4V with about 175k, nothing recently has been done to it and has absolutely no problems with starting in the past. Head was redone about 2 yrs ago (I was losing coolant) and the TB was done at that time.
I was on the freeway the other day traveling about 65 mph, and it abruptly stopped running. I briefly looked at the dash and saw an oil light and then battery light but more lights may have been on... I was concentrating on getting off the road...
I'm not a mechanic by any means but am usually able to work my way through with some guidance. I've done some looking around on here and I'm not sure where to begin looking for the problem.
I went through the no start list, looked under the hood for loose wires, switched out the 109 relay with a new extra I had, other than that still not sure where to go from there.
glow plug light is on when the key is on, and everything operates as normal except for the starting part. It turns over but that's it. All the electrical seems to work as normal.
Is there a Guru out there, or a "Guru in training" that would be interested in a little trouble shooting? I'd happily pay for your time. I'm trying to avoid taking it to the mechanic until I've found the problem, rather not pay them for the trouble shooting part.
thanks
thanks
