edthacker
- Joined
- Aug 22, 2009
- Location
- Cincinnati, OH
- TDI
- 05 Passat Wagon TDI Chainless, Colt Cam, 5 spd european tranny, rear air bags
Need some assistance repairing my 05 BHW with 330,000 miles.
It cranks(tach is stable at 200 RPM), cluster lights come on including glow plug.
In the past when a no start,a quick fuel filter replacement has cured problem.
Had a no start about 40 K ago, them 20K ago, then 5 K ago now this time filter does not fix. I can hear lift pump energize & there is fuel pressure going in & out of filter.
I did check all fuses and replaced the 209 relay. Do have 12 V at #28 fuse as well. Checked cranking voltage which was 10.6 volts then tried with booster cables attached to running car -voltage then at 13.8V. Battery is 5 years old
Took a peak at the cam belt & everything looks OK.
BSM installed by MoGolf 200,000 mles ago.
Colt cam shaft installed by Whitbread 125,000 ago 5 sp via Franz installed by Whitbread as well.
I'm without Vag com but do have a pocket scanner which shows no codes.
I did recently have a wire break at fuel temp sensor so I'm thinking maybe another wire has broken somewhere which at this mileage would not surprise me. Or I should throw a new battery in it?
Open for any ideas.
Open for any ideas.
