I cleared codes and got the following results.
Thursday,15,August,2019,17:28:15:42304
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-016-BEW.LBL
Control Module Part Number: 038 906 016 AB HW: 028 101 255 4
Component and/or Version: R4 1,9L EDC G000DG 7989
Software Coding: 0150038
Work Shop Code: WSC 00066 000 00000
VCID: 54A71445F45E0FEF6D-5140
1 Fault Found:
19464 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range - Intermittent
Freeze Frame:
RPM: 588 /min
Torque: 118.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Idle Stabilization: 0.0°KW
(no units): 35.0
Readiness: 0 0 0 0 1
Address 01: DTCs cleared
Address 01: Engine (038 906 016 AB)
17:29:56 Group 004: Pump-Jet Valves
903 /min Engine Speed (G28)
3.4 °BTDC Injection Start (specified)
7.7°KW Injection Duration (specified)
-2.0°KW Torsion Value
Friday,16,August,2019,11:28:20:42304
www.Ross-Tech.com
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Control Module Part Number: 1K0 907 530 H HW: 1K0 907 951
Component and/or Version: J533__Gateway H12 0150
Software Coding: 3FBF0B620F001002
VCID: 2C576CA58FAE772F15-8078
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 296559 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:39
Saturday,17,August,2019,07:48:47:42304
www.Ross-Tech.com
Address 09: Cent. Elect. (3C0 937 049 AD)
07:48:45
OFF Activation Relay Terminal 50
ON Activation Relay Terminal 15
ON Activation Relay Terminal 75
12.15 V Terminal 30 (left)
12.10 V Terminal 30 (right)
12.10 V Terminal 30 (ref.)
0.05 V Terminal 31 (ref.)
ON Terminal 15 (Input)
OFF Terminal 50 (Input)
ON Enabling P/N
OFF Terminal L (Input)
ON Terminal 15 (via LIN)
07:50:07
12.15 V Terminal 30 (right)
12.15 V Terminal 30 (ref.)
OFF Terminal 50 (via LIN)
Inactive Load Management
0.0 Short-Distance Operations
0.0 Critical Time Fraction
07:50:16
07:50:18
0.10 V Terminal 31 (ref.)
07:50:36
12.25 V Terminal 30 (left)
12.20 V Terminal 30 (right)
12.20 V Terminal 30 (ref.)
Saturday,17,August,2019,07:54:24:42304
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Control Module Part Number: 3C0 937 049 AD HW: 3C0 937 049 AD
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: 14058E234004150007140000001400000008730B5C0000
Work Shop Code: WSC 00000 000 00000
Additional Info: 1K1955119E Wischer 101106 020 0501
VCID: 6BD5AFB94A20B0175C-803E
3 Faults Found:
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
72 7D
VIN: 3VWCT71K16M849571 Mileage: 296550km-184267miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607080801
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51A91D51C84C7AC746-8004
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 296559 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E5B7D9121068D794-8026
1 Fault Found:
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FQ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 78FF80F50B760B8FA1-802C
2 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000627395
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 101106 020 0501
Coding: 00065535
Shop #: WSC 00000
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F5030541
VCID: 2A5B6ABD855A691FE7-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:28
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D06KYCJ
Coding: 0013889
VCID: 6CD7ACA54F2EB72F55-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME49512C61B
Subsystem 3 - Serial number: 6342MSME1278452FG
Subsystem 4 - Serial number: 6351HSME0B0A4F1EM
Subsystem 5 - Serial number: 6361HSME0B115E73A
Subsystem 6 - Serial number: 63727SME0B101805T
Subsystem 7 - Serial number: 63827SME0B0F5F43E
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0012021
VCID: 0305E71942B0585784-8056
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4640487
Coding: 0023203
Shop #: WSC 12345 111 45725
VCID: 2E5366ADB9B2053F3B-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:28
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068242066
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:29
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T27TL03
Coding: 0000003
VCID: 397945F170FCD2879E-806C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000075769019
Coding: 0001205
VCID: 3B755FF97AC0E0978C-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346774C5579E2FEF4D-8060
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 296540 km
Temperature: 25.0°C
Voltage: 12.20 V
Voltage: 12.00 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 74E7B4C5171E6FEF8D-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 239
Mileage: 296559 km
Time Indication: 0
Date: 2000.00.00
Time: 00:15:30
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000014903
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 32008001 Serial number: 00000028369018
Coding: 0001204
VCID: 3C775CE57FCEE7AF85-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio DE2 145 0176
Revision: 00145000 Serial number: VWZ4Z7F2131244
Coding: 0010401
VCID: 24478485E77EBF6FDD-8070
4 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000642234
Coding: 0001168
VCID: 3E7356ED69D2F5BFAB-806A
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0420
Coding: 0100101
Shop #: WSC 131071 1023 2097151
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000642938
Coding: 0001168
VCID: 3F8D2BE96ED8FCB7A0-806A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5161A1B4B47E2702-8078
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
004 - No Signal/Communication - Intermittent
End-------------------------(Elapsed Time: 02:09)--------------------------
This has been a long process due to work and other vehicle and life issues. I have checked grounds and wires to ECM. No visual defects. I am going to try to finish my wife's 2006 Beetle repairs and then get back on the Jetta. I had to replace the head on the BEW engine and found a couple boost leaks. I should finish that before I go back to work Friday and then my next time off will be dedicated to the Jetta.
I am leaning toward an actual ECM failure, but the short to the fuel pump needs to be addressed first. I disconnected the relay and when I put the relay back in I heard an audible arc, so I assume the motor is bad.
I will update when I get back on it. Thanks for all your help!
