Hey everybody, I'm looking for some help getting my ac up and running.
Details: 2000 mkIV jetta tdi, no power to the ac compressor
What has gone on so far:
Started with a simple resistance test on the compressor and it had infinite resistance. At the time I didn't test for power to the compressor. Ended up replacing the compressor, receiver drier, and condenser (cracked line while removing the drier). After getting the new parts installed I evacuated the system with a vacuum pump and started to refill the system but since the compressor didn't kick in I only have the system about half capacity.
Checked fuses 5, 16, 25, s164, and s180. All good.
Since that point I have tested for power at the compressor and have none (new compressor is good btw). Then I tested the High pressure sensor, ambient air temp sensor, and started to test the fan control module. I am really looking for help with testing the FCM. Specs and procedures that go with that. The fans did run when I got some fluid back in the system but I could tell a difference between slow speed and high speed.
Thanks for reading and any help provided!
