No power steering - 2006 VW Jetta // 1.9L TDI
BackToFixin
TX
2006 Jetta - 1.9 BRM
2006 VW Jetta 1.9L TDI (BRM) - 6 speed automatic DSG // ~290,000 mi
Just had the red "steering assist" light illuminate while parked at idle after 10 minutes of driving. Shut it off, went into the store, came back out, and light was still present with no power steering.
Got home, checked fuse #6 (5 amp) from the interior fuse box... nothing out of the ordinary. Pulled the codes (shown below) & cleared them... issue is still present. Help from anybody that has ran into this issue would be greatly appreciated before I start dumping a couple hundred $ into uneccesary parts.
(Also, the EGR code is a new one... prevous owner did an EGR delete ~100K miles ago)
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2555571
Coding: 0050078
Shop #: WSC 66565 257 00032
VCID: 64C7A63DA73260B147-8030
VINID: 0E69E290705BA06746186143144A592382
1 Fault Found:
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 466854 km
Time Indication: 0
Date: 2000.00.00
Time: 04:35:50
Freeze Frame:
RPM: 1134 /min
Speed: 22.0 km/h
Duty Cycle: 0.0 %
Voltage: 14.21 V
Mass Air / Rev.: 425.0 mg/str
Duty Cycle: 29.9 %
Bin. Bits: 00000000
Readiness: 0 0 0 0 X
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 070 0913
Revision: 04007000 Serial number: 00000504270128
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 183FC2CD2BFA74511B-804C
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 408F4AAD13EA1C9183-8014
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 70EFDA6D63CACC1133-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000140704
Coding: 14010E234004180000140000001400000008730B5C
Shop #: WSC 25038 444 85687
VCID: 2A5B08058596F6C1BD-807E
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 25038
1 Fault Found:
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 464929 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD03BJ6$
Coding: 0012627
VCID: 2E530415B97E9AE161-807A
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0A5C0A20A
Subsystem 3 - Serial number: 6342MSME0A7C6901H
Subsystem 4 - Serial number: 6351HSME08042576%
Subsystem 5 - Serial number: 6361HSME07765A34A
Subsystem 6 - Serial number: 63727SME07290E372
Subsystem 7 - Serial number: 63827SME0729043D%
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78FFE24D0BBA9451FB-802C
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023207
Shop #: WSC 25038 444 57535
VCID: 2B550D018A6CEFC946-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001056218458
Coding: 3F3F0B40071002
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 9
Mileage: 464929 km
Time Indication: 0
Date: 2000.00.00
Time: 10:07:57
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 9
Mileage: 464929 km
Time Indication: 0
Date: 2000.00.00
Time: 10:08:01
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36632C75412EA22129-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326B1065AD46BE0105-8066
2 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
00569 - Steering Motor Current
011 - Open Circuit
Freeze Frame:
Mileage: 6840 km
Temperature: 23.0 C
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09050F880F048051A0
VCID: 74E7D67D17D2F031D7-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377D217146245B2932-8062
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 31691F69A84085197C-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D510319B478E1F958-8078
End-------------------------(Elapsed Time: 01:50)--------------------------
BackToFixin
TX
Follow up:
Cleared the codes the other day and drove it around. Went down the road just fine, until the car tried to dart me into oncoming traffic while making a left turn. The red steering wheel light came on the dash again, followed by three beeps.
Went out to tinker with it a few days later, but the battery was completely dead. Stuck it on the trickle charger until fully charged. Also, my horn doesn’t work?
So far, I’ve:
1.) Checked & cleaned ground cables. They were tight and relatively clean before this.
2.) Double checked all fuses, including SA2 fuse in box A and cleaned the wire going to it. All appeared to be in working order… also checked continuity just to be sure.
3.) Cleaned out and applied dielectric grease to the plug running to the steering rack.
4.) Cleared all codes
All this to say, no fix…
Can anyone shed some light on this issue? …Pretty please?
Rx7145
Ohio
2006 Jetta BRM
You’ll need to use VCDS or a scanner to see what codes it’s throwing for the light. Could be steering angle sensor, but that’s just a guess.
BackToFixin
TX
Funny you say that... The first two times I scanned with the VCDS, it only showed the two codes I posted above, relating to the Control Module and Steering Motor Current.
Just went out to rescan, and it shows "00778 - Steering Angle Sensor (G85)", but the "00569 - Steering Motor Current" code is gone...
3 Faults Found:
014 - Defective
000 - -
Rx7145
Ohio
2006 Jetta BRM
So when you clear all the codes the Steering angle sensor comes right back?
BackToFixin
TX
Cleared the codes and no nothing popped up. Drove it around a quarter mile, and it still says "No fault code found." With that said, I still don't have power steering. I'm at a bit of a loss here...
BackToFixin
TX
Okay, just went back outside and plugged the VCDS in with the key on. The only code I get is:
1 Fault Found:
014 - Defective
Rx7145
Ohio
2006 Jetta BRM
Might be the rack.
BackToFixin
TX
Might be the rack.
Well I guess I’ll crawl into a hole and cry now…
Will post a follow up later. Thank you, sir.
P2B
Toronto & Muskoka, Canada
If you scroll to the end of that thread the OP solved his issue by cleaning all electrical connections associated with the rack including fuses and grounds.
Certainly worth a try before condemning the rack.
BackToFixin
TX
Read over the thread again and noticed that too. Shortly after, I did exactly what the OP explained at the end of the thread, cleared the codes, and everything appeared to have been working perfectly.
The next morning, I drove it ~20 miles to work with no issues. As soon as I fired it up to head home, I got the red steering light and three chimes again... no power steering. So I drove it home that way, no big deal... but wait, it gets better!
While sitting at a red light (almost home), the PRNDS indicator began flashing. I put the car in neutral, then drive, then sport mode, and the car wouldn't budge. Put it in park, shut the car off, waited a minute, started it up again, and every light on the panel illuminated like a christmas tree!! Also, the tachometer was not working, the PRNDS indicator had gone missing, and the car was stuck in park. So much fun.
So after sitting at the intersection for ~5 minutes, I gave it one last shot and fired it up. It went into drive and I was able to make it the last half mile home with all of the lights still on the panel. Plugged in the VCDS and pulled 60 codes shortly after:
Tuesday,20,May,2025,17:01:21:27103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
www.Ross-Tech.com
VIN: 3VWRT71KX6M666535 License Plate:
Mileage: 466920km-290130mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71KX6M666535 Mileage: 466920km-290130miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Coding: 0050078
VCID: 64C7A63DA73260BB4E-8030
8 Faults Found:
005670 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:22
Freeze Frame:
RPM: 2079 /min
Speed: 0.0 km/h
Load: 17.6 %
Voltage: 13.76 V
Bin. Bits: 11101000
Bin. Bits: 00000000
Bin. Bits: 10000100
005705 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:22
Freeze Frame:
RPM: 2079 /min
Speed: 0.0 km/h
Load: 17.6 %
Voltage: 13.76 V
Bin. Bits: 11101000
Torque: 131.8 Nm
Bin. Bits: 00000000
005686 - Powertrain Data Bus
P1636 - 000 - Missing Message from Airbag Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:28
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.38 V
Bin. Bits: 11101011
Torque: 129.3 Nm
Torque: 0.0 Nm
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:57
Freeze Frame:
RPM: 819 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 11101011
Torque: 129.3 Nm
Torque: 0.0 Nm
005687 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:57
Freeze Frame:
RPM: 819 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11101011
Bin. Bits: 00001000
(no units): 1.0
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:57
Freeze Frame:
RPM: 819 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11101011
Bin. Bits: 00001000
(no units): 0.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:42:05
Freeze Frame:
RPM: 798 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11001000
Bin. Bits: 00001000
(no units): 96.0
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Readiness: 1 3 0 0 X
Coding: 0000020
VCID: 183FC2CD2BFA745B12-804C
12 Faults Found:
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Time Indication: 0
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18274 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18082 - Powertrain Data Bus
P1674 - 000 - Implausible Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466928 km
Time Indication: 0
U0103 - 004 - - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Reset counter: 0
Mileage: 466928 km
Time Indication: 0
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 466929 km
Time Indication: 0
Revision: 00T12001
Coding: 0021122
VCID: 408F4AAD13EA1C9B8A-8014
10 Faults Found:
01312 - Powertrain Data Bus
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
01309 - Power Steering Control Module (J500)
01315 - Transmission Control Module
01299 - Diagnostic Interface for Data Bus (J533)
01317 - Control Module in Instrument Cluster (J285)
000 - -
VCID: 70EFDA6D63CACC1B3A-8024
VCID: 2A5B08058596F6CBB4-807E
Coding: 00065493
Shop #: WSC 25038
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 466885 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.55 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.65 V
ON
ON
OFF
OFF
ON
02389 - Release Signal Transmission; Position P/N
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Coding: 0012627
VCID: 2E530415B97E9AEB68-807A
4 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent - MIL ON
008 - Implausible Signal - Intermittent - MIL ON
014 - Defective - Intermittent - MIL ON
Coding: 0010021
VCID: 78FFE24D0BBA945BF2-802C
1 Fault Found:
00002 - Transmission Control Unit
Coding: 0023207
VCID: 2B550D018A6CEFC34F-807E
5 Faults Found:
9 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 54
Reset counter: 12
Mileage: 466885 km
Time Indication: 0
Date: 2000.00.00
Time: 04:47:59
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 54
Reset counter: 12
Mileage: 466885 km
Time Indication: 0
Date: 2000.00.00
Time: 04:48:02
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 15
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 52
Mileage: 466928 km
Time Indication: 0
Date: 2000.00.00
Time: 04:42:06
Coding: 0001269
VCID: 36632C75412EA22B20-8062
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit - Intermittent
VCID: 326B1065AD46BE0B0C-8066
5 Faults Found:
014 - Defective
Freeze Frame:
Mileage: 6920 km
Temperature: 47.0 C
Voltage: 14.00 V
Voltage: 13.90 V
00625 - Vehicle Speed Signal
Freeze Frame:
Mileage: 6920 km
Temperature: 49.0 C
Voltage: 13.30 V
Voltage: 13.10 V
Freeze Frame:
Freeze Frame:
Mileage: 6920 km
Temperature: 49.0 C
Voltage: 13.80 V
Voltage: 13.60 V
Component: KSG 0401
VCID: 74E7D67D17D2F03BDE-8020
Coding: 0001269
VCID: 377D217146245B233B-8062
Address 56: Radio
Cannot be reached
Coding: 0000144
VCID: 31691F69A840851375-8064
Coding: 0000144
VCID: 2D510319B478E1F351-8078
End-------------------------(Elapsed Time: 01:52)--------------------------
------------------------------60 Faults Found------------------------------
BackToFixin
TX
After doing a bit of research, the codes seem to be predominantly associated with the CAN Gateway. I'm unfamiliar with this system, as I've never had any electrical issues on this car.
To eliminate a few possibilities, I got the battery and alternator tested, both of which supposedly tested fine. I’ll be doing a parasitic draw test shortly with the driver's door and hood open for a few hours before-hand. Any feedback/input in case I'm doing this wrong? Any other possibilities?
Rx7145
Ohio
2006 Jetta BRM
Well a can gateway is cheap. I’ll give you one for the cost of shipping.
03Golfer
Canada
09 Jetta, 92 Toyota swap (ongoing), retired 03 golf
Definitely indicitive of powertrain CAN going down. Any of the modules on the bus can kill the network. Ideally, an oscilloscope is used to monitor the CAN signal while it's faulting, and you unplug the modules one at a time until it goes normal. A multimeter *may* be able to be used by monitoring voltage but it really doesn't give a full picture.
A fault steering rack could pull the network down. So could water ingress into any module or electrical connector on the network. Are there any CAN connectors/ headers shown on the diagram?
03Golfer
Canada
For your parasitic draw test, latch the hood latches, latch the drivers door latch, and lock the car, let it go to sleep for 20 minutes.
Basically I'll gain access to anywhere I may need to test, leave those doors open and latch them, then put the car to sleep. If you have power seats, make sure they're moved to wherever you need to give yourself the most space.
Often the module that is causing the draw (if it is indeed a module) will be causing other issues, so I would start by checking the steering rack.
Beware that if a bus is kept awake, other, non faulty modules on the bus may be drawing a current as well.
Use voltage drop across the fuses to determine draw. An infrared camera can be helpful, if you have access to one.
