dieseldorf
The T6 at my local walmart $21.xx
I saw Mobil 1 tdt in gallon or was that 5 quart jugs at the Wal Mart in Greenville , North Carolina Friday and also shell t6. The Mobil tdt it is the first time i seen it in years at a wal mart.__. Yeah, see my post above -- saw it in Kinston NC for the first time in 2-3 years; this weekend also saw it at "SuperCenter" in Wallace NC. Apparently it's back on the "suggested buy" list from headquarters.
That's expensive for TDT, more along the lines of the D1 ESP price. TDT is normally $25/gallon.I just saw M1 TDT 5-40 at OSH (Orchard Supply Hardware in California) for $35/gallon. No idea if that's a competitive price, but I was surprised to see it there.
i had the recommended oil from the dealer for the first 60k miles with regular changes. it gave me a real bad sludge issue. lubrication was bad/noisy, even with a warm engine. independent vw specialist used a cleanser that cleared the issue. he put in some mobil 1 full synthetic. since it wasn't matching the vw tdi spec, i got nervous and removed it after about 3000 miles...but the engine was 100% quiet/happy.
then i put in a "european formula" oil from oreillys. it explicitly met vw spec and cost substantially less than the dealer. but the only viscosity was 0-40. the temperature in the winter never got lower than 45 F. the engine was noisy when cold, and after a few hundred miles, even made a little noise when warm. i took it for the dealer and requested a full lube system flush. he said ok, but then said no way when he saw it was a tdi. no service avail for that in calif.
so i drained the oil, put in mobil 1, with some auto-rx and it was quiet again, even when cold. i got the highest "cold" viscosity, which was 15-40. i had oreillys cleaner for a couple hundred miles and it quieted it down but only a little. i think auto-rx has quieted the engine when warm.
for cleanser, i'll do another oil change in 1500 miles and drop, clean the oil pan. i like mobil and if they make something that is tdi compliant, i'll look for that.
i purposely mentioned my winter ambient temp here because i realize people in colder climates need to make a compromise. also, this is MY experience and realize others may not feel it's applicable to them. this was scary and i hope others can avoid it.
