BeetleDragon737
I apologize if this has been answered by other threads before, but it seems like diagnosing a heat issue has a few facets, and it's hard to distinguish between the effects of each - that is, thermostat, heater core, blend door.
I have foam blowing in my face and my vent selector barely changes where the air goes, so I know the blend doors are failing. My first question:
On the *Beetle*, can can all three blend doors be accessed without removing the whole dash? I've seen info on the Jetta, etc, but I'm unclear on how to access the heater box in the NB without doing all of this: https://www.newbeetle.org/forums/technical-how/41973-blend-door-diy.html
Also, I'm concerned about what else may be wrong. Although my heat is only barely warm, my cold comes through just fine. Does this mean more than just my blend doors are bad - maybe my heater core is gone too? Should I just replace it anyway if I'm taking all this stuff apart?
Extra info: Thermostat seems fine, as the operating temp is about 185 F
Thanks for any advice
