Ignition switch provides 12v to fuse 29.
Checks Ok, 12.8v with Ignition On
This goes to pin T121/37 of the ecu.
Ecu then send ground signal from T121/18 to the 109 relay.
Checks Ok, have good continuity from pin T121/18 to 109 relay socket terminal 9/85
109 relay then powers up fuses 32 (main ecu power, qa housing), 34 (solenoids, MAF,
glow plug module), 43 (PCV heater, brake switch)
Checks Ok, all 3 fuses power up when ignition is turned on, this is a good sign the ECU is working as it is powering up the 109 relay and sending power to the 3 fuses.
Of course, none of this can happen if you don't have a good ground to the ecu (T121/4&5).
Checks Ok, T121/4 and T121/5 had continuity to ground but there was some resistance from the pin in the connector to the ground points I checked. I read 13 Ohms from each pin to the engine block, and 29 Ohms from each pin to the neg battery terminal. I don't consider that to be high resistance, just more than I expected. I cleaned up the grounds anyway. This didn't seem to affect the ECU from powering up as it is controlling the 109 relay as advertised.
HTH.
Start at fuse 29. If that's not getting power, go to the ignition switch.
Checks Ok,
So far all the wiring I've looked at has been in very good shape for a 20 yr old car.
I'm going to pull the instrument cluster today and see what I can see in that area. All appears to be working there except the MIL (check engine) light and the glow plug light. Can anyone advise if there is a path through the instrument cluster that could cause this condition if there was a failure in that circuit.
This is turning into a real puzzle...
