Horn beep gone!!!
Thanks to the link radoroc offered the process was simple. Here you go - the VCDS procedure - All the usual VCDS disclaimers apply - Just figured this out this afternoon.
First select "09 Central Electronics" (you may need to have your car door's unlocked in order to be able to access this module).
Note choose "Coding 07" on the right hand side of the screen not "
Fault Codes 02" highlighted below.
Choose "Long Code Helper" from the screen below. Note the Current coding shown below is the coding in place after I made this program change. Your coding will be different - Be sure to screen shot it before making any change.
On the screen below, you will need to click in Byte 5 on Line 3 below. It's the 5th pair of hex numbers from the left. This brings up the check boxes shown below in section 3. Un-check Bit 1 Locking Confirmation with Horn active. Then click Exit in the upper left corner.
When you click Exit it takes you back to the previous screen. The new Long Coding will be in the new coding box. Click "Do It!" You will be prompted with something that says words to the effect "Coding accepted".
I tested this program change using both car remote key fobs. It seems to work fine with no other ill effects so far. Of course anything you do with VCDS you are doing at your own risk.
B/R specs
Current Rides:
'07 Grand Cherokee 3.0 CRD
'13 Jetta Hybrid SEL Premium
'88 Porsche 944 Turbo
