cherrybomb
The 2003 Beetle TDI H/B (Mfg. 3/03) will activate the flashing RED light when prolonged Idling W/O a/c on in 50 degree weather. Both cooling fans. work well and run either Hi or Lo speed with A/C (cooling and R134 good) )in hot weather. Have replaced the thermostat,, temp sensor in flange (Green), both 50A strip and 30 A green fuse on top of battery and the Radiator Thermal Switch.. Have read multiple threads plus Andybees and Oilhammer tips regarding the various tests on overheat and fan testing. We tested the Rad Therm. Sw. by jumping the red to other 2 wires and fans ran as suspected. 1. Will the red wire at Rad Therm. Sw be hot when ign. on ? 2.Where is it powered from, the FCM?' Found it strange the A/C and fans work well ; then when on manual air flow and heat, the fans do not operate when the light is flashing red. The mgf. date and changes from 5/03 confuse us also. We only have the Basic Free program from Ross Tech.
