eeonmomberg
Bew golf has been manual swapped and has had an issue since it was and auto with starting on the first crank, normally it would start amd then idle rough and die the first crank which lead me to believe it was a fuel issue, over the last 2 weeks when I go to crank it the starter would completely disengage while I'm trying to give it a long crank but would start up on the second try, however today the cars starter won't even engage amd the solenoid won't even click, I checked voltage at the connecter for the starter and it's at 11.97v, I tried to jump the starter and the first time I got a decent spark but the starter didn't even try to turn over, I switched out the starter and it didn't help at all, and when I try to jump the new starter I hardly get a spark at all if i even get a spark, I checked the relay and wires leading from the starter to the plenum chamber, then to the relay, and up to the ignition switch and everything looks good, minor corrosion starting in the plenum chamber on the brown connector pin 3 which goes to the starter relay but not much at all, im at a loss, idk what it could be, any help would be amazing, im suppose to leave state for a job this week and don't have a running car
