No boost till 2000rpm! Please help
Taizer
Haverhill
Pd130 bora
Hey people
I own a p130, it's got a egr delete and the n75 has been simplified.
I'm getting no boost till 2k rpm then it goes, it's almost like driving a sdi up to 2k ?
I've replaced all vac hoses and vac tested everything for leaks
I've put chemical metal around the tandem pump vac pipe
I've checked the actuator is moving fine
All OWV are working fine
Checked for boost leaks (not that it will cause it to boost from 2k up)
I'm at a dead end and dunno what to do next.
Hoping someone can help me get my car back to its potential
shaark92
Erath County, Texas
06 Jetta, manual. '12 Jetta, DSG
My Kerma Tune does that a little bit. Needs 2K to start performing. I avoid "cruising" <1800 RPM.
I'm unfamiliar with a p130 or n75. Sorry.
Good luck.
OhCdn
Canada
2002 Golf MK4
Hey people
The actuator could be moving but is it opening at the right time? If your actuator is not opening between 3-5 hg that will be your problem. Hope to hear back
