dadsdiesel
Very nice explanation above xsbank - enjoyed reading it!
Yes. But 'cold' means something like 0F. I've never measured where the activation point is. But I believe it is based on how long VW engineers think it takes for the engine to raise the coolant temp to produce heat (say 100F) from a starting point. If the ECU determines that it will take more than X amount of time, it turns on the plugs. Actually, it assumes the rate of heat increase is fixed at load.Are you suggesting that the afterplugs come on everytime you start cold?
It's Now Avaialble for PD automatics!!!TDIheater.com has not yet designed a heater to fit a PD engine with automatic tranny.
It's a marketing statement..."Our diesels don't need a block heater to start."I can't believe that something that would make such a dramatic difference to driver comfort wouldn't be documented in the owners manaul and made a selling point, especially where winters are cold.
We have you covered.... www.TDIHeater.com...I have always had block heaters in my other gasoline powered cars.
We offer a lower wattage (750 watt) for heated garage parked TDIs.I am planning to keep my car inside the garage during the winter months.
As far as warranty, the service managers at Volkswagen dealers I've talked to in regards to warranty all say that it wouldn't be a problem and a heater would not effect the VW warranty. As a matter of fact, I have a number of Volkswagen dealers who buy TDIHeaters in large quantities from me. Some of the Canadian VW dealers are replacing the oil pan heater under warranty with my TDIHeater at no cost to the customer! Many tdiclub.com members have also talked to their service managers and they've said it would not be a problem either. It would be like installing any other aftermarket parts and accessories to your vehicle to either personalize or to make it more functional. The TDIHeater doesn't change the coolant direction or decrease coolant capacity, and the installation doesn't compromise or modify any other components under the hood, besides removing one factory hose and installing the TDIHeater assembly in it's place. The TDIHeater itself comes with a 1 year replacement warranty for workmanship defects....by putting in a TDIheater does my warranty become an issue?
Me too! Hopefully by Spring, when my NB TDI DSG will arrive, there will be a TDIHeater available.I'm still hoping to see one for our NB's. Terry needs to either get a test mule, or see if he can check out clearance on one at the car dealers. I'm hoping for something to happen on the NB/DSG front soon.
