Ed27
I've started a new thread since I solved the no crank issue. After a clutch replacement my daughter's car in which she smoked the clutch in 5th gear to get it off the road. All of the shifter bushings failed at once. I have since replaced the bushing using DieselGeeks kit and have adjusted the linkage following his YT videos and it has no 1st 2nd and reverse. After a road test only 3rd 4th and 5th work.
In my other thread WildChild80 suggested "I ask that question because I had a 2.slow that I ended up swapping the trans for that issue, could only get 2nd and 4th, thought it was a simple adjustment but when I did the up and down test, it wouldn't make a full stroke without slight rotation."
Now after much shift play sitting in the yard I managed 1st and 2nd the shift does rotate for those two gears. But reverse is completely missing.
Any ideas?
Any ideas?
